404 Club
From ebay auction to cleaned, serviced and on the wrist in just over a week.
The latest 404 club offering. As expected it has a Soviet era  Raketa 2609.HA, and as is often the case, it arrived filthy and the crown wouldn't turn the hands.
It actually arrived a couple of days ago, but I hadn't had a chance to look at it.
Since it was raining today, I had a day off from trying to keep the garden under control, and  gave it a full clean both inside and out, and some home brew tractor oil and vodka mix and off it went.
OK that's a slight exaggeration, but I did decide to treat it to the witches brew neatsfoot and baby oil, rather than the good stuff,  so it also joins that unfortunate bunch, all of which are still alive, despite my dastardly experimentation.
It is now sporting a new old stock 18mm black leather Apollo band.
The leather on this batch of Apollo straps was a little dried out when I grabbed them as a job lot of four (also for <£4.04)
Neatsfoot oil on its own was used to wake up the leather and it now actually feels really soft.
I wont bore you with my limited set of servicing pictures. Instead, I'll point you to Marc's full strip down and rebuild of an identical piece here. ->
Thanks for those, they have proved very useful with several of these 2609.HA pieces.
I rather like the look of these, in fact I have another one on its way, also picked up for a pocket money price of course.
On 6/20/2021 at 12:56 AM, LittleWatchShop said:
Gots to me one of dem Russian watches!!  I was watching one a day or so ago and let it slip by.  Ebay is forever...so I will get one.
Well worth picking one up.
The most common issues are keyless work problems as described in Marc's servicing post. One or two I've looked at were so badly gummed up with junk and corrosion that it needed great care to free them up without breaking anything.
That and obviously the usual gummed up old oil and attempts by people with fat fingers to fix things, resulting in screwed up hairsprings.
Also watch out for the shims under the balance bridge. Sometimes there are none, sometimes one, and occasionally even two of them. They are easily overlooked when disassembling as they tend to stick to the back of the balance bridge or the main plate unobserved, only to then fall out later and get lost.
I think these USSR era watches are quite under rated and often overlooked, but with a little TLC they spruce up very nicely and if correctly serviced they run very well too. They are also pretty easy to service as there are not many parts, and no "gotcha" springs or weirdly constructed complications to deal with.
Edited by AndyHull
13 hours ago, LittleWatchShop said:
A little uninspiring.  It does run though...kinda.
The EB 8800 is the first movement I serviced. It’s also the first one that I broke (balance staff). 🙂
I like them ok. Easy (quick) to service and solid runners. I have at least 10 of them (half in Chateau/Lucerne jump hours).
10 hours ago, LittleWatchShop said:
@AndyHullwhat do you think about Vostok Russian watches?
Well they can be a little bit "agricultural" in their construction, but they are generally very robust.
I have this rather natty blue dialled Bostok Командирские (Komandirskie) that I'm particularly fond of, which I paid a bit more for than the 404 club rules allow (although not that much more), and a couple of other  that are 404 club members.
There are some interesting examples here too -> https://mroatman.wixsite.com/watches-of-the-ussr/komandirskie
They are by no means luxury watches, but they fun, quirky, a little bit different,  and fairly well built, and certainly if the price is right, then get yourself one.
I couldn't resist this, despite the terrible picture.
Yes I know. Madness. I just posted one of these a few days back, but it was three quid, (well three pounds and forty pence to be exact, no other bidders) and the other pictures in the auction showed that the second hand had moved, so it probably isn't a complete basket case.
Now I have three of them, one of which I am currently wearing (which is putting in a good solid +/- 10 sec/day performance).
Its fine. I'll just need to grow another arm, that's all.
Edited by AndyHull
  • Haha 2
The latest candidate, a Rotary Quartz for a pound.
Judging purely by the styling I would think it is late 1970s or early 1980s, but I could be entirely incorrect. If i is late seventies or early eighties then it might have an interesting jewelled quartz mechanism in it.
I'm hoping that the only issue is with the crystal, but given the price, even a complete basket case would not be a major disaster.
Some of the 404 club USSR Sekondas.
I have a few more, including a number of USSR era mechanical watches, and some duplicates of the ones above.
I also have some Poljot, Raketa, Luch and Bostok USSR watches from the same era.
Edited by AndyHull
I assume it is symmetric cushion. What are the dimensions?
I have an ambition to become the "crystal man" so I bought this one:
I have not tried it yet though. The drawback is that you have to have the original one to copy it.
"The glass and plastic lenses of today are termed "crystals" because of this seventeenth century influence."
I'm attempting to divine how that machine works based on other machines I've worked with in the past...
Top flips up/down. The collet on the left somehow holds blanks, and the stylus on the right traces the original? Or, no... The motor turns the shaft on the right, so it'd have to be the other way around... The bases slowly turn in unison with the handle on the right, the cutter is on the right, the original and a stylus (not pictured) on the left. As the plattens turn, the top plate slides left and right to trace the shape of the original as the cutter cuts the new blank. I think that's it. That's what I'm going with.
I serviced this one today.  I did not realize how the mainspring was configured...!!!!!!  Jack in the Box.  Ugh
Nothing broke, but getting the mainspring reassembled was...uh...interesting.
It is running fine now.
A couple of Kander 25 jewel Baumgartner 1582 automatics for for £1.60 each plus P+P
They currently look fairly terrible, and one is missing some parts of the automatic mechanism, however I am pretty certain I have a donor movement in the junk pile, so hopefully I can get them both working.
I posted about a Kander watch a while back, details below.
Edited by AndyHull
1 minute ago, LittleWatchShop said:
I am filtering for US sellers only...I think you guys are seeing much better deals over there.
I need to filter out US sellers here, as the postage to the UK is generally eye watering.
Recent Brexit related changes mean that EU sellers items now incur additional tax at point of sale, which tends to push them out of the 404 bracket.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
