New hobbyist from Atlanta, GA
Hello! I'm a new course enrollee from Atlanta, US. I've been interested in watches as a general hobby for a few years and have lately been more and more curious about what it takes to confidently dismantle and repair/service mechanical watches. After watching through all the courses, taking notes, and acquiring the basic necessary tools, I finally made my first attempt at a disassembly/reassembly of a cheap HMT watch from eBay. Although I lost the click spring (never to be found again), I was able to strip the watch and put it back together in working order. Needless to say, I'm hooked!
I suspect these forums will prove valuable in my near future, and I look forward to the day I'm able to contribute and not just learn from it.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
