"Louis XIV" alarm pocket watch.
imageproxy.php?img=&key=8c41f123521b3122Not rare, nor exceptionally valuable, but of my several pocketwatches, it's one of the most useful and endearing.  The third hand sets the alarm. At work I might go to lunch at different times, there is no clock in the breakroom, and dealing with protected information we must lock up our cell phones before duty. Watches are how we tell time there. My alarm tells me when my break is over.
Technically assembled by Public Watch Co, with a Baumgartner 222 movement, it is surprisingly accurate for what it is (that, and I spent quite some time regulating it). I think it's around 50 mm +/-.  Value-wise, it's probably a step up from "Dollar watches", but I love it anyway; it's alarm has been a handy reminder quite often.
I'd have to check, but I think it's a video that I've seen.  There are a few of these handy little watches out there.  Maybe I could post my own video here.  I'll have to film it in action!  That'd be a cool thing.
Edited by KarlvonKoln
Typo
So here is the requested video.  Isn't the alarm feature just the handiest doggone thing?   Sure, I could set an alarm in my smart phone, if it was required to lock it up, and if I didn't have to open the app, pull up the date, set the hour, then the minutes, then am or pm, then select a tone, then hit save (then look at the time on the screen and realize I now have to clock back in anyway).  Perhaps I exaggerate, and perhaps not, but this certainly seems way easier, even one-handed.
I had to trim the video down a bit, but it still seems to show enough about how simple it is to work it.
Weirdness ensued.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
