help procuring part for Patek
i recently broke my patek 5134 by winding a little too vigorously.  heard a click sound and can no longer wind the watch.
it has a 215 PS movement
after dissasembly, i see that the "under" wheel that the crown wheel is attached to (located under the barrel bridge) has a couple of broken teeth.
the wheel has 3 screw holes and a nub in the middle for the crown wheel to attach to.
from my searches on the internet, it appears this part is #421, but i am not sure, wondering if anyone can confirm correct part number
or has any ideas where to procure part.  i will attach a picture showing the part, its the silver part under the highlighted bushing with 3 holes in it.
I have no idea, but you'll hardly find any scrap movements to scavenge for parts on eBay, and Patek probably won't even bother to reply to any questions from a non certified watch repairer. I wouldn't be surprised if your only option will be to send it to Patek and pay for the repair through your nose. Sorry, for being so pessimistic. Anyway, best of luck!
EDIT: You could try to ask cousinsuk.com to source it for you. Searched for cal. 5134 but unfortunately no match...
Edited by VWatchie
The 215 is a quite common movement for a Patek Philippe, but as with all expensive watches the replacements are expensive too since they aren't mass produced.
Here you got one at the bay selling the wheel you ask about, the rest of the parts are out there too.
https://www.ebay.co.uk/itm/Patek-Philippe-Geneva-Cal-215-part-1x-under-crown-wheel-420-diameter-3-4-mm/133217216347?hash=item1f045d675b:g:ywkAAOSw4bhcJQ0P
For the price asked seems like learning how to make (CNC or not) this kind of parts may be a killer business.
Oops, didn't read carefully enough. Thought 5134 was the calibre number. ^_^
Here's a complete list of what CousinsUK have to offer for Patek cal.215 :lol::
sorry meant to say the ebay part doesn't quite match my part.  mine has a round nub in the center like the picture shows, not a square.
though i am now wondering if the square part can be rounded off.....
guess i'm still better off trying to get the right part if i can.
14 minutes ago, stony8868 said:
but thats for the crown wheel on top of bridge.  i need the part that is under the bridge that the crown wheel screws into.
I thought the crown wheel 420 is on the top like this one..
https://www.ebay.com/itm/PATEK-PHILIPPE-CAL-215-CROWN-WHEEL-NEW-WATCH-MOVEMENT-PART-420-/123903845490
The other part is as the dude states the wheel going under the crown wheel..
Maybe take a shot of how yours look like would help a bit..
4 hours ago, stony8868 said:
here is a better picture of the part, its labeled 4 in the side window
Looks like a interesting video, do you have the link to it saved?
Have you looked if the part nr 4 isn't actually 2 pieces?
The lower which is in contact with the winding pinion might have a upper removable part called a crown wheel core.
I think it used to be called no 423 in other Patek movements. The core usually fitts on the upside the lower crown wheel. It has a bronze bushing fitted to it when the bridge goes into place.
If you look closely at the lower picture you can see it most likely is a two piece part.
Push in the middle of the wheel with some appropiate tool to see if it doesn't split appart.
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
