help procuring part for Patek
i recently broke my patek 5134 by winding a little too vigorously.  heard a click sound and can no longer wind the watch.
it has a 215 PS movement
after dissasembly, i see that the "under" wheel that the crown wheel is attached to (located under the barrel bridge) has a couple of broken teeth.
the wheel has 3 screw holes and a nub in the middle for the crown wheel to attach to.
from my searches on the internet, it appears this part is #421, but i am not sure, wondering if anyone can confirm correct part number
or has any ideas where to procure part.  i will attach a picture showing the part, its the silver part under the highlighted bushing with 3 holes in it.
I have no idea, but you'll hardly find any scrap movements to scavenge for parts on eBay, and Patek probably won't even bother to reply to any questions from a non certified watch repairer. I wouldn't be surprised if your only option will be to send it to Patek and pay for the repair through your nose. Sorry, for being so pessimistic. Anyway, best of luck!
EDIT: You could try to ask cousinsuk.com to source it for you. Searched for cal. 5134 but unfortunately no match...
Edited by VWatchie
The 215 is a quite common movement for a Patek Philippe, but as with all expensive watches the replacements are expensive too since they aren't mass produced.
Here you got one at the bay selling the wheel you ask about, the rest of the parts are out there too.
https://www.ebay.co.uk/itm/Patek-Philippe-Geneva-Cal-215-part-1x-under-crown-wheel-420-diameter-3-4-mm/133217216347?hash=item1f045d675b:g:ywkAAOSw4bhcJQ0P
For the price asked seems like learning how to make (CNC or not) this kind of parts may be a killer business.
Oops, didn't read carefully enough. Thought 5134 was the calibre number. ^_^
Here's a complete list of what CousinsUK have to offer for Patek cal.215 :lol::
sorry meant to say the ebay part doesn't quite match my part.  mine has a round nub in the center like the picture shows, not a square.
though i am now wondering if the square part can be rounded off.....
guess i'm still better off trying to get the right part if i can.
14 minutes ago, stony8868 said:
but thats for the crown wheel on top of bridge.  i need the part that is under the bridge that the crown wheel screws into.
I thought the crown wheel 420 is on the top like this one..
https://www.ebay.com/itm/PATEK-PHILIPPE-CAL-215-CROWN-WHEEL-NEW-WATCH-MOVEMENT-PART-420-/123903845490
The other part is as the dude states the wheel going under the crown wheel..
Maybe take a shot of how yours look like would help a bit..
4 hours ago, stony8868 said:
here is a better picture of the part, its labeled 4 in the side window
Looks like a interesting video, do you have the link to it saved?
Have you looked if the part nr 4 isn't actually 2 pieces?
The lower which is in contact with the winding pinion might have a upper removable part called a crown wheel core.
I think it used to be called no 423 in other Patek movements. The core usually fitts on the upside the lower crown wheel. It has a bronze bushing fitted to it when the bridge goes into place.
If you look closely at the lower picture you can see it most likely is a two piece part.
Push in the middle of the wheel with some appropiate tool to see if it doesn't split appart.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
