ETA 7001 mainspring problems
Hi everyone. Since getting back to work i took on a watch for a service with a manual wind eta 7001 and thought it would be smooth sailing.
Unfortunately ive found the mainsprings suplied for this movement via cousins dont even come close to hooking the arbor as the inner loop is too wide, and are much too brittle to adjust (just failed my second attempt)
Does anyone know where/what i can get a mainspring thats sure to work?
I see gleeve and co sell a mainspring for an eta 7001 but i suspect its not an original but the the same generic, since the price is almost exacly the same.
A colleague advised i tried with two pairs of sturdy, short tweezers, so that is what i did, i spent considerable time on it going little by little, but there appeared to be no point at which the spring would change shape before snapping or splitting, i don't believe the ends on this particular spring are annealed.
2 springs in the bin and no closer to finishing a nearly due repair, not really willing to give it another go, you know.
I think if i can't find a more promising mainspring to order I'll just have to have to put it back together and send it through to central workshop and apologise for the delay.
Do you have the original mainspring to measure? The reason I ask is that you've been supplied a 1.00 x .12 x 300 x 9.5 whilst ranfft says you should have a 1.00 x .11 x 260 x 9.0
So is a GR2453 more appropriate than a GR2467 if ranfft is correct?
There's a guy on daBay selling what he says are "Peseux stems for mechanical watches" that includes one for a Peseux 7001, which I believe is the same as the ETA 7001. If they are indeed Peseux branded NOS springs, you should be in luck. Not cheap, but should work if ETA 7001 = Peseux 7001. The seller is in the USA. Good luck.
I'm not going to say they are wrong as I've used sturdy tweezers to make light adjustments before. However, it is not ideal, especially when you need to modify the radius significantly. They will potentially cause acute bends which is more liable to cause fracture. I've been there and done that.
It may have been worth trying to anneal the inner coil further on the second spring. But it's easy to say that now with hindsight.
If you are in the UK then I can have a look through my spring selection in case I have one.
Hey I hope I can help you. I live in China and there's a considerable amount of spare parts of 7001 taking out from the original movement including the whole barrel assembly and mainspring. Where do you live? I see if the selling can ship to you or not? As for the prize I guess one barrel assembly will be ¥100 that's around $14.
Thank you all very much for your helpful replies.
I feel silly for not checking ranfft first, not the first time that website has gotten me out of trouble.
do you believe the inner hook would be on a tighter coil?
I might just try anyway. I'll certainly try and check and compare the dimensions of the original.
Edited by Ishima
Dont mean to keep bumping this thread but i just though id report back and let you know i tried the mainspring suggested by WatchMaker and it worked a treat. It was a near thing, but it hooks without adjustment and now the watch is working well.
Thank you a great deal.:woohoo-jumping-smiley-emoticon:
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
