Case for Seiko NH25A Movement
Hello all,
I watched a video on assembling your own watch from parts on ebay and got so excited I promptly ordered parts that don't work together.  I purchased a Seiko NH 35A movement and a 28.5 mm dial and hands.  These all work great together.  However the case I bought was WAY to big.  I have been searching all day for a case the correct size but cannot find anything.  Any suggestions on sources or other ideas?
Thanks in advance for any advice.  I love the videos and discussions.
Nick
I think the nicest cases you can get are from Seiko 5 watches. Any cheap 700x or 7s26 one will do. Stainless Steel, so can be repaired and polishing perfectly.
Otherwise you will have to spend a lot of time and effort adapting.
Ok, so here is the next dumb question.  Would a chapter ring fix the problem and how do you know how to size (probably going down from about 38MM to 28.5?  Are there standard size charts somewhere?
Thanks again.
Nick
No. The chapter ring is the one that may sit on top of the dial, with minutes or other markings. Perhaps you are referring to a spacer, or movement ring. Your NH35 comes already with one of grey plastic one. If it's size is not adequate, a watch manufacturer would replace it with a different one.
There are no standards. Movement size can be expressed in old French lines but that is just indicative, then each movement has a technical drawing for casing that show all the size including the very important hand and stem height.
If you are OK with bodging up an holder ring, there are assortments that you can buy, or use whatever common material at home. Otherwise making it perfect requires 3D printing, or precise metal turning and milling, even if hand made.
If you have a 3d printer then it's possible to make a movement holder to position the movement correctly inside the case.  I've done this for a custom watch I made.  I also printed a dial is it was a skeletonised movement.  It takes some time and effort to get right, here's my prototypes...JyCoBLI3OZ4ILpEfte4GB37r7aZfsQz5d2nJZ0qPkSP1pw8BZH3ZvqmpszDxHQpJd1yrbr8mz-E1FQD7slljks30nYDV7SOfuHMXgHzIQFB99f07bLNjGF_rQ-oqO6ZK6OYptz-C6dqSCBCf_rjTn_eD0fPqOg9skqYZFmg3azsxJjxOsoP79vN7Q6gviTOdfIDYTPJZiQr61yqZPyYP_YAdaapJBzo5W66cWOYlDA-rPFewHKhZOAl90ebEIibf53Or83O4S-lsCUifFuoe5fp91aQ1HPHX85R6P2M5z7nzZuZc7Z8b2qv0Y6DkLN8iw5EIfpM8Ti8GcD48e7goxrD-bx94UF7_9lsLLvfKdgWROmpFLkCdhQgu4WkodZVBlm-DER0Pnd-EUb75q1b79v6tWVX0rGVnJNeCXkU1t_djrwCfNEJ63B95vhkfDC8Fc-LvlNTHUTL1WgYl_Ro89ACMUNpQjXnLIhWFNveUOHAC0wqKkBkCRX-IBjQujohtecLbL3UVXCuPwKBObHyifB1H3VpzWQJv62jIvbf2gNcREs38-FeGJRNkl7egi5GWFpIKFYdnrQKD807PcTpyVBJFVlwB9cOdJsApEHWHwXOVMZNDOsAmcIGxTRMK6wte_zUq5wCiImxgPCCGdP5giQlDKG2H7xn--hDEf6eOuA0V5-vbMmrHQWCk=w847-h1129-no?authuser=0
If you are not opposed  to used parts try speedtimerkollektion. You can buy used cases in lots. 28.5 mm dial diameter  is pretty  much a seiko standard  size. Pay attention  to stem location. It varies
There are now many suppliers of aftermarket cases for Seiko 72XX and NHXX movements. Have you looked up CrystalTimes? Theirs are  SKX-type (diver) cases that accept the parts you have (in addition to others required). Namokimods just announced "Rolex Explorer" style cases (two vintage sizes) that accept the parts you have. The later are currently pre-order. There are others as well.
My apologies if you've figured this out already!
Seiko diver's knock-off cases starting $99?
Fat springbars $22?
Ahaha! I'll rather buy the genuine article, or if it is about made in China, at their real prices.
Is there such thing as a JDM SKX case, specifically? Is the case from an SKX007J made in Japan? You can't get an SKX OEM case, seperately, now anyway. My personal "knock-off" SKX cases are at least as nice as my OEM ones, if not better (drilled lugs). $79 should about do it for an aftermarket SKX007 case, which sounds pretty good given the current $250+ full price for an OEM SKX007J from a reputable online seller (way up since being replaced by the new "5"). Sure, grey market is cheaper.
Fat spring bars should be about $6/pair from any seller. $22?
There is not, only the dial and rotor change on these.
You can, but at exorbitant prices. https://www.cousinsuk.com/category/filter/seiko-case-parts and search 7S26-0020.
Sorry, $14 a pair on Namoki. Easy to find for much less any of their items.
So it sounds like, if someone is interested in an SKX-type case they can buy the exorbitantly priced "genuine article", which could be made in China -- or a high-quality aftermarket case, undoubtedly made in China, for a reasonable price. Given that the aftermarket options have proven their quality and value to me, I can recommend  them.
Or buy a complete diver's for about $100 and if it's only for the case, have a lots of spare parts.
Maybe is just more practical to wear a complete, original Seiko watch as I had suggested before.
Thanks.  I have not solved it yet and was just going to live with it.  I just find it ugly and will definitely look at these suggestions!
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
