Best worklight?
Unfortunately, it is not possible for me to arrange things so that I can work in natural daylight.
From personal experience, can anyone suggest which type of LED overhead lamp would be best suited.
Round, or square, 300mm or so and, preferably, as thin as possible.
Thanks.
There's a long LED lamp sold by a number of horology houses. Mark Lovick uses one in his videos after a certain point for reference, and I think he even talks about it briefly in one video.
The thought process that has resonated with me is that an elongated light across one's work station and over the task at hand helps mitigate shadows cast by hands and tools. Brighter is better.
That said, I have an old Edison style desk lamp with an LED bulb in it, because it's what I had, the above mentioned light is over $100, and I believe it requires a separate base or a bench mount of some sort that I don't have/isn't practical for me at the moment.
12 hours ago, KarlvonKoln said:
Thought about getting an "OTT lamp" (imitates natural sunlight) but they're a little pricey so I haven't yet.
You can get natural light LED bulbs and tubes which are very economical and practical to arrenge a working, studying or living area. It's just a mid range white temperature, nothing special about.
Thank you, sir. I hadn't done too much looking before, but if I can get them I will.  I am curious to see if there is much difference between them and the regular LEDs.
LED for sure nice light little  heat.I have a  nice  cheap  intertek 5005686. My wife got it somewhere. Probably  Walmart. It is nice for close  up work.It neither blinds me nor burns me and it let's me see WTH I am doing.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
