Barrel Help
Hello all, this is my first question post.  I did introduce myself in the other section though.  I have been practicing repairing on a lot of old 50s junk watches.  This way I don't feel bad if I break them.  This is the second time I have come across this issue.  After I strip, clean, oil and reassemble these watches, everything works well except the hour and minute hand do not move, or move very little.  The amplitude is fine and the second hand is keeping good time.  I think it might be because of the strange additional gear on the barrel in the picture I have provided.  It is attached to the bottom of the barrel arbor and is friction fit.  The barrel teeth drive the second hand and the balance, and this additional gear then drives motion works.  I think that because it is friction fit, it is slipping too easily and that the friction of the motion works is stronger than the friction of this gear.  Has anyone seen this before?  Should I put some sort of breaking grease on it to make it not turn as easily?  I am guess this is what prevents the pulled out crown from affecting the mainspring.  Any insight would be welcome.
Please do always provide the caliber.
The seconds hand moving indicates the movement run is runing, hr and minute hands not moving or move little, points out to loose canon pinion.
Check and tighten the canon pinion.
Here are a couple more pictures.  Yes these movements don't even have jeweled pallets, just metal spikes, and only one jewel.  I figured they aren't worth restoring, but they seem great to learn on.  Every time I try and look up one of the companies online there is little information and they all say "mass produced swiss movements rebranded."  I will definitely open it back up and give the pinion a try.  I had just not seen that extra gear on the barrel in any of the youtube videos I have described and it seems part of the movement works.  Thanks for taking the time to respond.
I just took the watch apart again and its not the canon pinion.  There is no through pivot on this watch so the canon pinion just sits on static metal, its the weird extra gear that is supposed to drive it.  I put a small mark on it and left it for a while and that gear is not turning at all despite being attached to the barrel.  I think I just need to somehow increase the friction of that gear so that it only slips when setting the time, but not when the watch is ticking.
I figured out that it was a Baumgartner 866 movement.  I found a site that said this: "indirect minute, hand friction clutch on barrel (Roskopf type)"
So, I think what i am going to do is peen the inner ring tomorrow so it presses more firmly on the the friction fit gear.  That should increase the friction in the same way tightening a canon pinion would do.  I will post pictures.  Luckily I have a scrap barrel to practice on.  I'm not sure how "tight" a perfect canon pinion feels, but I'm guessing its something like "it turns, but only if you put some work into it."  I am still very new at this hobby.
So, one hit with the hammer and pin and the gear turned much more tightly. Once I put it all together it work as expected with the hour and minutes turning properly.  So, for this kind of movement, its the gear on the barrel that needs to be tightened instead of the canon pinion.  The watch is running very fast, but that is a whole different problem.  Thank you to everyone that responded.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
