Weishi washi
gary17
Hey
I am trying to make head nor tail about using this weishi machine.
Can some one look at these pics and tell me if this is a good reading or bad.
The movement is a valjoux 22 chronograph from 1937 and keeps great time.
I used this watch because it is such a good time keeper as machine suggests.
ButrIMG_20200630_194136.thumb.jpg.5fbbe0dd0c6bbc306c23a983489dc08a.jpglooking at the readings the watch is in a terrible state.
cheers
gary
I had an Omega auto (forget the caliber) I bought and wore for a few months before deciding to check under the hood. It was within about 5 seconds/month, amazing timekeeping. Put it on the Witschi before servicing, had about 200 degrees of amplitude and a timing delta in 6 positions of well over 100 seconds. After service it had healthy amplitude, and a delta under 15. Never kept time as well though! Maybe 30 seconds/month (still fantastic, but it was almost "magic" before).
Mayhap it's like nickelsilver is hinting at. It's possible your positional error rates more or less cancel each other out. The numbers aren't great, it probably needs a service, but it may be like Mr. Burns (may be a US reference only accessible to a certain age group...). He has all the diseases known to man, plus three new ones, and they're all keeping each other in check. If they fix one ailment, all the rest will come crashing down and kill him. Poor amplitude, high positional error, rickets, etc., but it all works out.
Edited by spectre6000
It seems like a "spot the difference" quiz - if those pictures are different positions then it looks pretty consistent (good).. sometimes it can be surprising how different a watch seems to wear vs on the timing machine. The amplitude (is low) and rate (slow) otherwise suggest it would benefit from a service (not so good).
I'm presently wearing a 7 jewel pocket watch which is beyond economic restoration.. having suffered some bad past repairs, shows wavy traces, slightly poor amplitude after swapping to a new and stronger mainspring, and poor positional consistency.. taking it off at night, and wearing during the day, It's gained 1 second over the past 4 days (this is more luck than my skill).
Edited by JGrainger
addition
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
