Quartz watches - low battery
Do all quartz movements indicate low battery with the customary second hand jump or do some keep going and losing time until the battery runs out?
In particular I have a Hattori in a watch which is 3 weeks old and in that time it has lost exactly 1 hour. It has 2 year warranty but postage would be more than what I paid for the watch. I'll change the battery and see what happens.
No, they don't all do this.
I suggest that you measure the battery before blaming it. It could be also a lose cannon pinion.
Hi  as jdm explained  not all watches exibit the sweep jumping as a low battery indicator, usually on better quality ones, the lower grade ones just either go down slowly or stop. Check the battery for the 1.55v if lower than 1.3 change it as some don't deliver the power. I have had them stop and a new battery fitted has been going a year later. but some times the watch its self is at fault being gummed up or dirty therefore the watch demands more of the battery witch fails quite quickly, canon pinion , sticky gear train , rotor bearings sticky, or dirty
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
