Making a watch run backwards?
Just now, nickelsilver said:
6 minutes ago, HighMans said:
Hello! This is a bit of an odd question, but if I wanted to make a mechanical watch run backwards -- what would technically need to be done?
Display the time backwards or actually mechanically run backwards?
Actually run backwards
I would think you'd need to reverse the mainspring and click, flip the escape wheel and pallet fork ... theoretically. That should reverse the train of wheels and the motion works. Any complications, though ... that would be complicated. ;)
Edited by eccentric59
Hm, interesting. I'm tempted to buy a cheap movement off ebay and try that... Or I wonder if I could commission someone here? Hahaha
Hmm, starting at the beginning the winding system (winding pinion, clutch) would need to be remade to work backwards. The stem would need a left hand thread so custom stem and crown. Click would need to be reversed in function, so some machining there. Barrel arbor remade with reverse hook, barrel modified (if not automatic) for reverse hook. The rest of the gear train is ok, up to the escape wheel. This would need to be inverted. The pallet fork could possibly be inverted depending on design (the guard pin needs to change sides at least), possibly remade. That should do it.
There's a Zenith/JLC caliber, 845, that "runs backwards" in the sense that the escape wheel and fork are reversed due to an extra gear in the train. Time display is normal though. It's like 5x6 lignes though, tiny. Barrel is about 5mm diameter.
Some 8 day movements have reversed escapements too, if you're really adventurous you could rob the escapement and fit it to another watch.
Yikes! That's very involved haha -- do you know of any movements that actually run backwards?
Hahaha, yes, some quartz watches that have had their stator bent just a little, just right will run backwards. Mechanical, I don't think that the niche market was ever enough for someone to engineer, tool up, and produce such a thing.
I know it was was asked, but my read makes me think there may need to be some clarification behind what he means by "run backwards" as opposed to "display time backwards". Asking in the first place implies a less than thorough understanding of how watches work, and it's not hard to imagine someone who has such an understanding interpreting that as meaning the train is running backwards, while a less technical understanding would interpret the same as meaning the hands are simply turning counter clockwise. Similarly, a technical understanding of displaying the time backwards would mean the hands turning counter clockwise, where the non-technical understanding could mean anything from the dial simply having the numbers mirrored to the same understanding.
When I say backwards -- I mean the hands are running counterclockwise instead of clockwise. I'd like to have a watch whose hands run counterclockwise instead of clockwise.
46 minutes ago, clockboy said:
WHY ??
Because! It's interesting!
Yup. Called it.
So the train doesn't need to run backwards at all, and all that stuff about clicks and springs and forks being reversed is the answer to an entirely different questing.
What you are asking still requires some competent machining, but is much less complicated depending on the movement.
4 minutes ago, spectre6000 said:
Yup. Called it.
Alas, it's probably still a bit out of my budget to commission someone to make/modify a movement to do so.
That is done with relative ease on Seiko, sorry I don't have the full details on how. Search "Seiko backwards" on YouTube.
If you pull the crown on a some Seiko 5s (7S26 I know does this first hand) and put a small amount of torque on the stem as if you are going to set the hands counter clockwise, the second hand will run in reverse. May or may not be what you mean though.
Mechanically, in theory, and for most mechanical movements, you only need one extra 1:1 gear ratio in the train to run the thing backwards. However in practice, machining the extra gear, pivot holes, jewels etc,  and moving things about to incorporate it would be a fairly major undertaking.
Having said that, there appears to have been a small cottage industry in the former USSR converting 12hr movements to 24hr movements, so perhaps someone, somewhere could to this for you.
EDIT: Things are a lot simpler if you want to hack a quartz mechanical clock movement to go backwards. -> https://www.instructables.com/id/Make-a-Customized-Clock-that-Runs-Backwards/
EDIT2: I would suggest that reversing the coil wires, rather than "reversing the magnet" per the above instructable may be your route to success, since in many cases the 'magnet' in question is possibly a ferrite bar, and only becomes magnetic when the coil is energised.  The permanent magnet in the thing is the rotor, furthermore, some mechanisms rely on a ratchet arrangement to ensure the motor only runs in one direction, so either the rotor, or the ratchet, or more likely both would also need to be modified. Flipping the rotor magnet, and reversing the action of the ratchet may not be as simple as it sounds. The rotor may have a bunch of sloped poles in it like a stepper motor, sloped to ensure it only turns one way.
In theory, the same change(s) would work with *some* quartz watch movements, depending on their construction.
Edited by AndyHull
Hahaha ok I guess there was a miscommunication early on. To get the hands on a mechanical watch to go anticlockwise is fairly simple, but a handful of gears need to be cut and almost certainly custom hands ( unless you're ok that they're off cententered).
If having no seconds hand is a satisfactory compromise then this can be done with a simple module on the motion side. But I suspect this would not be a satisfactory compromise for you as the novel effect would be dampened quite a bit without a seconds hand ticking backwards. In which case yeah all the stuff that nicksilver says for a mechanical movement or what AndyHull mentioned for quartz.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
