Clock from a MIG fighter
In 1999 a friend came from Russia to stay with me for a week to attend a cell biology conference in my city. As a gift, she brought me a clock out of a MIG fighter. It stopped working and I opened it to see if I could find out what was wrong. I found that the jewel that holds one end of the balance wheel had broken. I had no idea how to find a new jewel for it or if it was even possible. I also didn't want to go taking the whole thing apart for fear of never being able to put it together again. Does anyone have an idea who, in the US, might be able to do this?
Thanks,
Mike
Thanks,
Mike
Assuming his was a cold war MIG then the clock, if luminous, probably used radio active material to achieve the luminescence, the dust from which is VERY dangerous if inhaled. Great care needs to be used when opening luminous clocks and watches from the1960's and before.............
That's very interesting. I'm very much into Russian wrist watches but have never worked on any Russian clock. I know Vostok makes ship clocks available to anyone interested. Not sure new members can upload pictures but that would be a good and interesting start.
Is it one like the one below? That one is mine. Parts are difficult. You can get a new balance wheel or a set of hands, or a dial, even a nice display stand, easier than any other bits. Is it the jewel in the balance bridge? If so, you may find it easier but not financially feasible to purchase an entire watch and possibly scavenge the balance, though it would be a waste of one watch for another. I put in a question with a seller on eBay who is selling a handful of miscellaneous gears for one of these to see if they have a bridge available, assuming that is the culprit. Mine has an issue with the lower balance jewel Chaton. It had moved away from it's propper position and would cause the balance to overbank randomly. I seem to have it sorted now. They were built in a relatively robust manner, most bits are quite easy to disassemble. I suspect the reason there are so many available is likely because it was easier to replace a faulty watch rather than try to service one. Most were likely sent back to the factory but again, it was just simpler to ship out a new one rather than to bother fixing them. These watches were in military aircraft so they were certainly subject to vibration, impacts, shocks, and wild temperature swings to say the least. I would imagine it wouldn't take long before issues began to arise. The were usually placed low in the instrument panels to make getting at them easier when they failed. 2 thumb screws and two wire connectors were all that were required to remove these. As I said, mine is running reliably now as long as I don't fiddle with it too much while it's running. I would be curious to see photos of yours. I'll let you know if the eBay seller gets back to me.
My AChS-1 watch
There upper balance jewel.
Here is a shot of one properly mounted in a Mig-29 Fulcrum.
Edited by FLwatchguy73
you're in luck, the seller on eBay I messaged has a complete balance arm available.
quoted message below....
New message from: remwatch (650)
Hello.I have a balance bridge. But I also have jewel for it.
HERE is the link to the original listing. Contact the seller and see how much they want for the Bridge.
While is true that Radium is an hazardous tolerance, this routine warning given every-time that an old watch is mentioned is greatly exaggerated. The danger becomes real manly when the substance is ingested, or inhaled, and for prolonged time. Occasional manipulation of watches do not present danger whatsoever. Otherwise all of the old watchmakers and dial / hand manufacturers would be dead or fell sick back in the 60's already, fortunately is not so.
https://en.wikipedia.org/wiki/Radium#Hazards
Edited by jdm
Agree, but with degraded lume flaking off the danger is in breathing in the dust, hence the warning........
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
