Seiko 7S26-02F0...
I should have know this could happen, but I went into the project with blinders.
I was almost finished putting together my Seiko 7S26-02F0. I could see it on my wrist within minutes. Then I found out how plastic parts hold up over time. I picked up the Day Date Corrector Wheel and notice one of the teeth was not level with the rest. I bring it in for a closer look... a crack from top to bottom. And as I'm looking at it, the tooth falls off completely. I picked up the tooth and it crumbled in my fingers. I found the same thing happening with the other plastic parts within the watch. Is this common for Seiko parts? I got is from someone who only got it serviced as a Seiko shop, so this kind of baffles me.
Not common, maybe it took extreme heat, or was  faulty batch. You should be happy as you're working on mov't that cost new $25 in an improved version that hacks and manually winds, everything is easy to get, imagine if it was 100 times as much and virtually impossible to find.
That is good to know. And yes, I am thankful that I need a $5 part rather than a $100 one. One of the reasons I started on a Seiko.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
