Rolex GMT Master Service Sheet
Rolex is extremely paranoid company. Technical information is extremely hard to get there are a few parts lists out there but it's only for the older stuff. for the most part there's almost 0 technical guides out in the wild as a PDF. this leaves the only source that I know of to get anything that resembles a modern service guide is eBay. Like the manual below really beautiful in color.
https://www.ebay.com/itm/ROLEX-CALIBER-3186-MOVEMENT-TECHNICAL-BULLETIN-SERVICE-INFO-MANUAL-BOOK-ENG/302150612993?hash=item4659947801:g:SbEAAOSwiONYOznJ
56 minutes ago, Peterburke340 said:
Rolex-3135-tech
slandis [ AWCI-DOTT ]
SOrry Peterburke340, this did not come through if you wanted to attach a document.
you can find your parts lists here
https://www.cousinsuk.com/document/search?SearchString=rolex
8 hours ago, Peterburke340 said:
Rolex-3135-tech
I've attached the PDF that's missing from up above. I think this is about the only service guide available the problem is if you look at the table of contents it's supposed to 40 pages long the reality is it's 20 pages. So this means if I place you get a service guide is to physically by one nobody is bothering to scan them into PDFs at least that I'm not aware of anywhere.
Rolex-3135-tech.pdf
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
    • Haha. You're just in a wicked mood today John 😅
