I have gotten bit by the collecting of watches bug. I am fascinated by all the watch repair videos and find most to be very relaxing. As my collecting proceeds I was passed down a watch from my late father. Nearest I can tell its a cheaper model Benrus quartz watch. There are no identifying marks on the back and apparently it opens from the crystal side of the case. Can anyone offer any information. I'd like to know the model or time of manufacture. I'm probably not going to get it working. This is for sentimental purposes. Thank you.
Just try a fresh battery, chances are that it will work. If it doesn't start try some quick spinning on it axis, and pulling the stem out and in. If no luck I think the back is removable to identify and replace the module. A new strap and it will be a nice watch to wear.
The battery access hatch looks to me to be of the type that was used on electronic watches of the early seventies, perhaps late sixties. If I'm right, and it does say "Electronic" at the bottom of the dial, it probably has a movement in the ESA 9150 line. 9150, 9154, ...They are interesting in that they are battery powered but keep time via a balance wheel rather than a quartz impulse. They are often fixable, but are a bit finicky. And my experience with an ESA 9150 that I actually got running is that it run fast. This MAY be due to the battery it was designed with was in the 1.35V range, which are not longer available. At least I couldn't find one. It may also be due to something being amiss with its hairspring. (?)
Look up "ESA 9150" and/or "ESA 9154", and you'll see what they look like, and perhaps what to expect. Good luck.
This is a Benrus Electronic that is an  ESA 9154 movement. My feeling is that this is what you'll find when you are able to open it up. There are magnets on the balance that sometimes attract and capture any screw that dares come loose in their vicinity. The one I got running had two screws stuck to the magnets at the balance, IIRC.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
