Vintage Seiko quartz (1969-1989)
This thread may be a flop, but at least it will give a couple of us a place to show off very specific parts of our collection. Please feel free to share your vintage JDM or export Seiko quartz watches here. I think 1969 to 1989 is a good range and a great period of time for Seiko quartz watches.
My first vintage, Seiko, JDM, quartz finally arrived from Japan today! It's a 1975 model 0923-8040G. I'm absolutely over the moon about it! The dark emerald green is one of the sexiest colors I've ever seen on a watch. The seller's pictures literally did it a disservice. I think, like @JohnD, I have a new addiction! I'll be adding more Seiko JDM's to my collection. Hopefully starting with a sleek blue one.
This could just get a 'bit' picture heavy.....I haven't counted them for a while but I have at least 50........:startle:
Here is one to be going on with.....Its a 0903-8007 from January 1975....and as it has the 0903 movement it has a feature that I don't think any other Seiko movement has, a trio-lingual day wheel, in this case English, French and German.....
Edited by JohnD
I doubt that anyone will post up a picture of their 1969 Seiko Quartz on here as the only one that fits that bill is the original Astron and there are very few of them about.....;) Here's my earliest, August 1972 3803-7040....
I'm on the hunt for a birth month and year for me. One of those things only I will know and appreciate, but nonetheless, i enjoy a challenge. There are a half dozen or so on eBay currently. Of those, only two stand out for me. A Grand Seiko and a King Seiko with only the King being somewhat reasonably priced. I sure wish that unknown, rich uncle would hurry up and die and then will me his fortune! :D
Edited by FLwatchguy73
If the King Seiko that you are looking at is the 5625-7111, then there has to be nicer looking watches that fit the bill for about that 'reasonable price' (though that is still at least twice as much than I have ever paid for any watch!;)).....
I must admit the the Grand Seiko 5645-7010 does look much nicer, but it is just a 'tad' more expensive!!:startle:
Edited by JohnD
Given that you appear to be seeking March 1973, have you given any thought to one of the Seiko electronics? Either EL330's, Like my one here:- (though mine is an April 1972 one)..
or EL370's fit the bill .......
This one is spot on, with March 1973 serial number
but is an immaculate one and just a 'bit expensive'..........
    • Instead of using tweezers, put a piece of rodico onto a toothpick or pegwood. Then set your spring to the rodico, this way the spring is not under any tension when floating it back into the bloc. As you bump into the bloc when trying to find the entrance the rodico will give but still holds onto the spring ie. You wont have the rigidity of tweezers.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
