ETA 2824-2 hand wind stuck
Alright ladies and gents, first post here but I plan on sticking around a lot more as this is the first problem (of many more to come I'm sure) I've ran into when fiddling around with a movement.
I opened a 2824 and took off the rotor, auto mechanism and the first wheel to more or less practice on and mess around.  After reassembly it winds freely, but now the hand wind feels like it's jammed in the first position.  Turning it backwards, it clicks but clockwise it is stuck.  I took it back apart and removed the bridge again along with the click, put it back together and same problem.  With the auto bridge off it hand wound fine (actually a lot smoother than normal) but once the bridge and rotor goes on, I can barely turn the crown in the first position.  All other functions are fine.  Is it a meshing problem?
Sounds like ratchet wheel intermediate wheel pushes on the ratchet wheel, check that it's arbour falls into jewel hole.
Keep turning the rotor clock&anticlock while you are tightening the two screws to the auto bridge.   Good luck
Well I got it to loosen up following your advice but it is still a lot stickier, and I noticed while winding it the rotor was under tension while doing so.  Looks like a keyless works problem to me?
And excuse my ignorance for this question but is there any harm in just pulling the auto bridge off completely and running it hand wind?
There is no harm in taking out and running it without the winder-device, why not find and fix the fault though.
 I gather it manual winds alright, so keyless is Ok.
A fault may exist in the self-winder device itself, a broken pivot or jewel, worn reversers or the rotor bearing. Also broken jewel to the ratchet wheel reduction wheel which is located on the barrel bridge.
I would tear down and visually inspect the all autowinder parts. Take pictures in various stages of tear down, comes useful for reassembley also to show us if needed.
Good luck
Good luck
I was more curious as to the overall function of the auto mechanism on the watch and if it’s ratios would effect the running, thanks!
I took off the reduction wheel because I noticed the ratchet wasn’t meshing in a certain position when turned and it looked like it was raising up.  on the underside it looks like it was torqued and there is a burr that formed, I will try to take a picture but I don’t have the best phone or macro equipment.
Sounds like you found the fault.
Thanks for your insight, it looks like it’s going to have to stay manual wind because the rotor screw shot off into the abyss.  This is my first foray into watchmaking whatsoever so mistakes were made and learned from.  Cheers
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
