ETA 2824-2 hand wind stuck
Alright ladies and gents, first post here but I plan on sticking around a lot more as this is the first problem (of many more to come I'm sure) I've ran into when fiddling around with a movement.
I opened a 2824 and took off the rotor, auto mechanism and the first wheel to more or less practice on and mess around.  After reassembly it winds freely, but now the hand wind feels like it's jammed in the first position.  Turning it backwards, it clicks but clockwise it is stuck.  I took it back apart and removed the bridge again along with the click, put it back together and same problem.  With the auto bridge off it hand wound fine (actually a lot smoother than normal) but once the bridge and rotor goes on, I can barely turn the crown in the first position.  All other functions are fine.  Is it a meshing problem?
Sounds like ratchet wheel intermediate wheel pushes on the ratchet wheel, check that it's arbour falls into jewel hole.
Keep turning the rotor clock&anticlock while you are tightening the two screws to the auto bridge.   Good luck
Well I got it to loosen up following your advice but it is still a lot stickier, and I noticed while winding it the rotor was under tension while doing so.  Looks like a keyless works problem to me?
And excuse my ignorance for this question but is there any harm in just pulling the auto bridge off completely and running it hand wind?
There is no harm in taking out and running it without the winder-device, why not find and fix the fault though.
 I gather it manual winds alright, so keyless is Ok.
A fault may exist in the self-winder device itself, a broken pivot or jewel, worn reversers or the rotor bearing. Also broken jewel to the ratchet wheel reduction wheel which is located on the barrel bridge.
I would tear down and visually inspect the all autowinder parts. Take pictures in various stages of tear down, comes useful for reassembley also to show us if needed.
Good luck
Good luck
I was more curious as to the overall function of the auto mechanism on the watch and if it’s ratios would effect the running, thanks!
I took off the reduction wheel because I noticed the ratchet wasn’t meshing in a certain position when turned and it looked like it was raising up.  on the underside it looks like it was torqued and there is a burr that formed, I will try to take a picture but I don’t have the best phone or macro equipment.
Sounds like you found the fault.
Thanks for your insight, it looks like it’s going to have to stay manual wind because the rotor screw shot off into the abyss.  This is my first foray into watchmaking whatsoever so mistakes were made and learned from.  Cheers
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
