Waltham Calendomatic
Do i got this Waltham watch with an fhf 606 movement only problem is I can't take the movement out of the case. It turns but it doesn't come out. It doesn't look like a 2 piece case. I don't see a way for it to come out the front. Any help is appreciated. 41db9343f10b39c56d614e301f2545b6.jpg3b237ace6f780be60e3f0d673d10c867.jpgaf28ec18a57f9386ddbdc78b3116ae09.jpg
Sent from my SM-A102U using Tapatalk
it looks like the movement is being held in with the casing ring?
Normally the watches where they go out the front of the one piece case usually the dial side appears to be physically bigger than the backside. yours it appears bigger on the backside that's the way the movement goes out.
With that shaped crystal aperture and no removable bezel, there is no way the movement is a 'front loader'. As said above the casing ring needs to come out first to extract the movement out of the back of the case....
That's what I thought but the movement ring, if it is that, won't budge at all. I've applied some decent force, enough to where I'm uncomfortable applying anymore, and it won't come out. I'm thinking maybe it's really jammed in there and was going to grab a hammer and stake to see if that will move it at all.
as the movement ring formerly held the gasket in place was there any signs at all of moisture?  then the movement ring looks like a really tight one anyway and it's probably relatively thick. So if you that anything that resembles moisture that's going to be bad for getting it out. Then one prying on it it's not just going to pop off on one side you going at the very slowly pry all the way around and raise it to slowly if it will raise at all. Worst-case but extreme caution a little bit of penetrating oil might loosen it up but penetrating oil likes to penetrate and probably will get all over the dial which is not where you want penetrating oil to be.
so let's go for an extremely bizarre thought of fantasy basically. If it went out the front side typically as I said the crystal would be big usually around to take the crystal out the movement falls out. Gore has the possibility coming out sometimes as a ring holding them in. You are crystal is smaller than the back so just taking the crystal out will do you no good and it's an odd shaped crystal it be really hard to just pop out. So if it did go out to the front there would have to be a ring that holds the crystal and it would really be big so if you look on the side of the case is there anything that looks like a super tiny crack all the way around?
No there is no evidence of moisture whatsoever. Yes, as it's easily seen, there is no way it comes out the front. The dial is larger than the crystal. I will then try, as you suggest, to slowly pry it out.
For sure that movement ring should come out. I wonder if someone glued it in position if it's that stuck?! :blink:
I'd try and find something metal and strong with an 'L' shape and a short lower limb of the 'L'. Almost like a very small right angled allen key but where you've chopped the lower 'L' limb down to about 5mm or so. Hook this under the movement ring at the gap the stem enters and apply even upward force.
You might try replacing the movement screws and using them to lever on a bit using narrow jawed pliers. Perhaps that would get you and edge to start up? It's something that I might try, using care of course. You might want to remove the rotor, if it is possible without having the movement out. Good luck.
Edited by MrRoundel
So it is confirmed that whomever had this watch must have used some sort of adhesive on it. Don't you hate it when ignorant people try to fix things?
Well I appreciate the suggestions. I tried using some penetrating lubricant, it forms a shelf in the movement ring so it doesn't seep off and into the other components or the dial, and it seems like did something to loosen it but not enough. Any other suggestions that don't involve a possible breakage of the movement? Acentone maybe? Idk just thinking out loud. Thanks all for everything.
Penetrating oil isn't going to affect the adhesive and I'd be wary of sloshing fluid around in general anyway ... if any of it gets beyond the ring and mars the dial you're going to be kicking yourself.
I can only repeat the advice I've already given. Have you tried this? It's probable a few dabs of superglue were used; it's strong but a shearing force will normally break the bond. Applying upwards force at the gap in the ring should start a break and you continue from there. You won't damage the movement if you're careful but if you're concerned then, as already suggested, you can (part) diassemble ... something you'll be doing anyway since we assume the purpose of your quest is for a service.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
