Bayard carriage clock
chriseames168
Dear clock man,what I am saying is the air spring is not staying level when it moves back and forward it has got a lot of up and down movement too so it. Stops running as hits the side plate,looks like the pivot hole may be worn so maybe why it is getting the side unwanted movement, thank you again for your help,
This is not the type I thought of. It sound to me as if the balance staff might have broken, if there is too much play. Can you remove the two screws and remove the balance complete and look at the balance pivots, also the jewel holes, then could you post a photo, I can then advise you on what to do.
Hi,Yes it does wobble,when I put the clock face up lay it down the clock runs perfectly,like it did before,the balance wheel spring does still sit in ok the plates and does have some movement on each side of pivot hole so I think the pivot maybe worm of salf pin could be,but to be honest,not sure on how to repair,old hippy has ask me to take the unit out and take photos and he may advise me,have you got any idea as clock was also running perfect and just stopped one day and now get this wobble problem and doesn't keep running,only runs ok now when face up or down.,thank you again Chris.
Wobble of the wheel points out to either a broken pivot or warped wheel, that it stops reinforces the broken pivot assumption.
Hairspring coil is to be concentric( concentric circles), if coils are pushed to the side, it would need to be sorted out to bring all circles back to concentric, level and flat.
Once you take the balance complete out, both above said faults will be obvious and easy to see what we are talking about and pics help.
Hi A balance behaving as you have said would points to a broken staff pivot or jewel as the pivots when correctly fitted keeps  the balance verticle  with minimum of side shake and end shake. It is possible that the balance spring is deformed,   The only way to be sure is to remove the platform escapement and check.    BEFORE removing the escapement remove ALL power from the mainspring or you risk damaging the movement.       The attached PDFwill give you guidance.      cheers
LaBounty-ServicingAPlatform.pdf
    • Getting back to the issue which is us guys repairing or just enjoying horological exploits. The big worry now is how sound is Cousins as company going forward. The of cost if this 8 year legal battle will be astronomical. Cut backs will happen noticed already how the Cousins catalogue is half its size this year. The main supplier going out of business will hit the UK horological community in a big way.    On the Brexit issue it was about a sovereign country being able to make its own laws and trade with any country in the world. I cannot see what was wrong with this. For those who wish to re join the cost would be very high indeed.
    • Yes, it's the same (old) song and it's getting worse & worse;
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
