Date Wheel movement
Hope everyone is well and not suffering too much eye strain. On the ETA 2783 -1....Could someone please explain the correct function of the date drive wheel or at least one of its components, the small copper coloured pin which emerges from the centre hub, gets ready to turn the date wheel, fails to do so then disappears behind the hub until the cycle has passed. Is the reason it fails to turn the date wheel because the spring is weak or date wheel too tight in its location or some other reason?  The pic is a Garrard S76/28 which I think is very similar.P1010007.thumb.JPG.b591f34d71e316f64a7672ffa786add4.JPG
Edited by chrisdt
error
That is because I loosened the plate at 14 to see if it was binding. The date wheel revolves easily by the 'Quickset' method but will not move by moving the hands or by normal working of the watch
Well lets try to explain the function... There use to be three positions on the setting lever.
1. Winding
2. Date setting
3. Time setting
In position 2 the setting lever pushes (the date corrector lever) the setting wheel onto the date corrector.
The date corrector has three paddles that will turn the date ring in one direction.
Due to it's design you cant switch the date backwards.
In position 3 the setting wheel will engage the minute wheel . The minute wheel drives the Hour wheel.
The hour wheel drives the intemediate date wheel, this is held in place by the date indicator guard . On the date indicator driving wheel there should be a smaller wheel which drives the date indicator driving wheel. the intermediate wheel must turn free in the guard .
On the date indicator driving wheel there should be a spring loaded pin which allows for date shift in one direction (clockwise) but not in the other. Sometimes this springloaded pin is to worn or dirty so it will not grabb onto the date ring.
The date jumper will ensure you get a snappy dateswitch and later on keep the ring in position.
The dial is held in place by the date indicator guard and the minute work cock. These two must be exactly flat or the datering will not move.
So in this picture the date indicator guard looks beaten up and as previously said the date jumper is out of position.
Edited by HSL
Swinglish
Thanks HSL for your very detailed and instuctive reply. I appreciate the date jumper is out of position in the pic but when in position and the hands turned the date driving wheel engages with the teeth of the date wheel then takes the least line of resistance and is pushed in by the teeth towards the hub without moving the wheel at all. Thanks OH I will try it with a new one.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
