Enicar 1145b balance
Hi
Theses parts are from a balance from a Enicar sherpa 600. Cal 1145b.
Has anyone any idea how it goes back together.
I was fitting a new spring when it just fell apart.
The parts sheet on cousins does not show the part in detail.
Any help or suggestions appreciated.
Cheers
Gary
Hi Gary    part 307/1 regulator with stud holder fits togerther with part 364  the stud holder and then part 324 incabloc setting passes through both parts and into the balance cock, which is then reversed and the clip fitted to secure the setting.   work in a plastic bag as the clip is likley to try and escape.
The u shaped thing goes under the cock and locks the balance jewel setting which goes from the top. The stud holder and regulator go below the jewel setting above the cock.. usually the regulator above and the stud holder closes to the top of the balance cock.
Anilv
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
