Enicar 1145b balance
Hi
Theses parts are from a balance from a Enicar sherpa 600. Cal 1145b.
Has anyone any idea how it goes back together.
I was fitting a new spring when it just fell apart.
The parts sheet on cousins does not show the part in detail.
Any help or suggestions appreciated.
Cheers
Gary
Hi Gary    part 307/1 regulator with stud holder fits togerther with part 364  the stud holder and then part 324 incabloc setting passes through both parts and into the balance cock, which is then reversed and the clip fitted to secure the setting.   work in a plastic bag as the clip is likley to try and escape.
The u shaped thing goes under the cock and locks the balance jewel setting which goes from the top. The stud holder and regulator go below the jewel setting above the cock.. usually the regulator above and the stud holder closes to the top of the balance cock.
Anilv
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
