- 0
Asked by
Amateurwatchbreaker,
Similar Content
By chatlourd
I have a Looking Thomas Earnshaw - Longitude - ES-0025-05 and as you can see from the photo below the hand on the month dial has come off. In order to put it back on I need to remove the movement / dial from the case but I cannot seem to remove the crown / stem in order to do so. Any ideas?
By ColinT
My dream is to own a Franck Muller watch and I think and hope I’ve found the perfect one. It looks old and beat up, perfect for restoration but need help seeing if this is 100% real!
By Amateurwatchbreaker
I bought a vintage bulova sea king automatic at a antique mall for 80 dollars and I discovered the reason for its lower cost. It appears that it was someone's project watch that they sold. It has a 11 Anacd movement and the rotor is stuck. It can move but it grinds against the metal underneath it. The middle portion of the rotor(with the engraving) is loose and moves independently of the rest of the rotor. I have no clue how to remove the rotor as there are no screws on it. Is this a deeper problem than just the rotor or can I fix/ replace the rotor?
I have a watch movement that I have hunting for a case for a long time now. I bought the movement rather cheaply as I absolutely love the patina on the dial. The movement is an Wittnauer 11arg (as 1361). When the rotor turns the automatic assembly slips (or maybe the mainspring). The pictured gear slips when the rotor turns. I can still wind the movement by hand however the automatic assembly slipping I believe causes the mainspring to unwind. Does anyone know what is wrong/ what I can do to remedy it?
Thanks for your help,
Amateurwatchbreaker
I have been on the hunt for a vintage titoni airmaster for a while now and I have my eye on one but I am questioning whether or not it is a Franken watch. My main concerns are the spacing on the dial is too large-it appears that the movement may be loose in the case. Secondly, the caseback does not appear to be a Titoni caseback. Is this a "unknown" reference or is this a fake/franken watch? I need to know pretty soon a I am the current highest bidder and I may cancel my bid.
eBay link:
https://www.ebay.com/itm/402565751132
By watchfellow · Posted
Thank you for the response Poljot. Nothing really special about the crown I guess, probably just me being lazy to look for a new one (and this one looks aesthetically great). I will try option 2 before I start the search, although to be honest I have in the past tried to do just that and been unsuccessful. I've also tried option 3 in the past and never had any luck with it. I always end up mangling the washer and am not happy with the result. -
By LittleWatchShop · Posted
LOL, last night my neighbor was over for happy hour and I am telling her about my watchmaking renaissance. She says she has this watch that belonged to her grandmother...wondering about it. So she runs it over today and hands it to me to check out. Oh my! -
Thanks, will the paint 'suspend' itself in the gap? It's a slot in the hand...there's no surface for the pain to sit on.
Hello I have a question about the watch dial I'm working on. The numbers: are they painted on or lumed? I've scraped away the "2" and I'm wondering if I should paint it or lume it. If I'm going t repaint it, then what type of paint would I use? Was it common to lume numbers? Thanks in advance for any help that can be provided. Michael
I bought it from JerseyMo. Ask, he may have what you need.
Question
Amateurwatchbreaker 2
I have a watch that I am fixing up for myself. After lots of research l, I concluded my watch is a 1960s Hamilton Stormking VII. As my watch needs a new crystal I ordered one from ebay that is for a Hamilton stormking VII. When I got it in I immediately realized that it doesn't fit. The replacement seems to me about 1mm larger than the original. (I dont have a caliper). Is this even a Hamilton Stormking VII? Or did I get the right crystal but I have to modify it before it fits?
Link to post
9 answers to this question
