Battery replacement procedure
I've been pottering around with mechanical watch movements never paying any attention to quartz watches.
Now I have ladies Tag Heuer Aquaracer here, pretty little watch with diamonds and I certainly don't want to mess it up. I'd imagine it's straight forward, remove the caseback, take the old battery out and put the new one in, not touching anything in the process.
Is there anything I need to watch out for? I'm wondering whether I need to pull the crown out to disconnect the circuit etc.
There is always a better way to do a simple job. You may take the steps that better apply to your situation
  • Remove the band and clean it separately. If leather apply a specific product.
  • Clean the case carefully before opening it
  • Use a good and proper opener so to have zero chances of the tool slipping
  • Clean the gasket groove and any other trace of dirt around
  • Check voltage on the new battery,  you want a bit more that 1.55V
  • Check well if any screw need to be losened to ease the battery out
  • Handle the battery with plastic tweezers or finger coats only
  • Some modules have an AC pad to be shortened to battery to get restarted
  • Some modules require a lot of button pressing and perhaps reading the manual to reset sundials correctly
  • Set date one day earlier, then set time so to be sure that it changes at midnight
  • Check the gasket, if any wear of deformation replace it with a new one which fits perfectly even if you have to order it
  • Mark the date on the caseback
  • Apply a little silicone grease before reinstalling the gasket
  • Remove stem, clean it all carefully, apply hp-1300  to all  contact areas and silicone grease to its gasket
  • Blow air to module before closing it
  • Do a pressure testing
  • Brighten the case by hand with cloth and a touch of Dialux bar more suited to the case material
  • Present to owner with a proud smile
Now you  know how to turn a 2 minute task into a one hour one.
Edited by jdm
Well, better proof of that idea will be hard to find! Great post!
Makes me remember a discussion where someone claimed a mechanical watch typically takes about 1.5h to service from start to finish by a professional. Guess you would have to skip "Blow air to module before closing it" and some of the other steps to be that "productive".
Thank you for the tips.
I'm more than happy to turn it into one hour job, it is a hobby after all.
All clear to me with cleaning, gaskets, greases, plastic tweezers etc.
It's as you say, shorting something, no buttons here but I'm not sure whether the crown needs to be pulled out into a certain position etc. I've been trying to find the service manual but I can't find it. It is a Tag Heuer WAY1413 if anyone knows where to find the service sheet.
TH is just the watch manufacturer. Once you remove the back you can identify the quartz module being used or post its picture here for others to tell you about.
17 hours ago, jdm said:
There is no need to remove the stem (except for optional cleaning and lubrication) when changing the battery on the above or any other quartz module.
I will remove the stem. I'm not going to do much with this watch but I want fresh grease on the gaskets while I'm replacing the battery.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
