VX32E date wheel stuck
25 minutes ago, Rishah said:
Placed everything like this but the top part keeps popping out , any suggestions
Looks like some part is broken or reassembled incorrectly, being the cost of a new module less than 10 Euro it might be an option to replace it completely.
Edited by jdm
15 hours ago, Rishah said:
That's what I was thinking as well , just quick question the watch I am working on has date at 5 PM mark while the available movements have either 3 or 6 option, which one to buy
It depends on the shape of the date window, the one is your picture is actually date at 6.
Edited by jdm
    • Hi. Sounds like a problem clock, can you post some picture# of the clock and the parts in question please.       Thank you
    • The first broke while i was using a dremel to shape the jumper spring at the join, i guess you call it the fixator, the disk grapped hold and flicked it off . The second time same place but while i was filing.  This steel feels more malleable, it is annealed steel. Working out the detent on the jumper is a real. pain in the butt.
    • I'm trying to get a balance spring Mantel clock to run to time - even with the regulator set to Slow it's gaining 40mins a day (the balance spring was damaged on receipt so it may be shorter than it should be - can't think why else it should run fast, especially as it is quite dirty & apparently hasn't been working for some time.). Anyway, looking closely at the train I've noticed the pre-escapement wheel is slightly 'dished'. Could this have been done by a previous tinkerer to get around a problem that should have been addressed by e.g. bushing pivot holes?
    • Hi Rich, now i realise that you spring broke. how did it broke, may be when grinding the fixator part with the dremel? If so, then guess You have let it to vibrate free, this is wrong. One must keep the spring pressed with finger to boost the vibrations, other vice it resonates and breaks.
    • The movement is so called 'Tongji', standard chinese movement. The stem can still be used with the help of extender.
