Rotor Issue
I'm working on a Seiko 7625 movement in which the rotor rubs against the three center screws of the self-winding assembly. The marks from the screws can be seen on the rotor.
What is the best way to resolve this?  I've thought about placing a thin washer between the rotor and self-winding assembly or filing down the screw heads but not sure which is the correct approach.
The reason it rubs is because there is wear in the bearing. Proper repair is to replace the bearing. Sorry no leads on where to source a bearing. I think I did cannibalize one from an Orient but that was a few years ago.
Good luck
Anilv
p.s. Even if you do file down the heads of the screw My guess is that the rotor will then hit the edge of the automatic device bridge.
Edited by anilv
Reduce the distance between the two Disks that center arbour are mounted on.
Use a staking punch or a metal tube with ID larger than center arbour OD. tap on disks to push em closer together, thereby taking the slack out.
Use of a thin washer like you say works too.
Edited by Nucejoe
use a dial washer.
Correction,   Reduce the distance between the two Discs mounted on the bearing arbour.
5 hours ago, watchweasol said:
Hi  Ithink the best way to fix this is either a new rotor complete or a new bearing  as the origional is worn and will continue to do so .
It will have to be a new rotor because the bearing only is not sold separately on this class of Seiko. It can be separated and put back but the success of that depends on the tools available and the skill of the person.
Mark came out with a very timely video this morning in which he discusses whether it's worth repairing an early 70's Seiko 5. The watch shares a lot of similarity with the 7625 that I'm working on and like the Seiko 5 has lots of wear. I spoke to my customer about this and he's good with it. He just retired having worn the watch for most of his career. He doesn't plan to wear it in retirement but it does have sentimental value and he would like to have it operational. That being the case, I filed down the screw heads and the watch is working fine. I did not put a washer underneath the rotor as I had mentioned earlier as I was concerned that the additional height might interfere with the case back.
Thanks to everyone for your comments.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
