Rotor Issue
I'm working on a Seiko 7625 movement in which the rotor rubs against the three center screws of the self-winding assembly. The marks from the screws can be seen on the rotor.
What is the best way to resolve this?  I've thought about placing a thin washer between the rotor and self-winding assembly or filing down the screw heads but not sure which is the correct approach.
The reason it rubs is because there is wear in the bearing. Proper repair is to replace the bearing. Sorry no leads on where to source a bearing. I think I did cannibalize one from an Orient but that was a few years ago.
Good luck
Anilv
p.s. Even if you do file down the heads of the screw My guess is that the rotor will then hit the edge of the automatic device bridge.
Edited by anilv
Reduce the distance between the two Disks that center arbour are mounted on.
Use a staking punch or a metal tube with ID larger than center arbour OD. tap on disks to push em closer together, thereby taking the slack out.
Use of a thin washer like you say works too.
Edited by Nucejoe
use a dial washer.
Correction,   Reduce the distance between the two Discs mounted on the bearing arbour.
5 hours ago, watchweasol said:
Hi  Ithink the best way to fix this is either a new rotor complete or a new bearing  as the origional is worn and will continue to do so .
It will have to be a new rotor because the bearing only is not sold separately on this class of Seiko. It can be separated and put back but the success of that depends on the tools available and the skill of the person.
Mark came out with a very timely video this morning in which he discusses whether it's worth repairing an early 70's Seiko 5. The watch shares a lot of similarity with the 7625 that I'm working on and like the Seiko 5 has lots of wear. I spoke to my customer about this and he's good with it. He just retired having worn the watch for most of his career. He doesn't plan to wear it in retirement but it does have sentimental value and he would like to have it operational. That being the case, I filed down the screw heads and the watch is working fine. I did not put a washer underneath the rotor as I had mentioned earlier as I was concerned that the additional height might interfere with the case back.
Thanks to everyone for your comments.
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
