Should I give up on this pocket watch
Sell it on to someone who can.
I can't make a balance shaft , its too much effort  so I'm pretty content to just replace them if I can source parts. Otherwise it moves on.
Anilv
Hi   the problem with old english lever and fusee watches was the manner of their manufacture, Plates made by one person the wheels cut by another and all assembled by the "maker". There are subtle differences in a lot of them that require broken parts to be repaired or re made individualy or if you are lucky finding a donor watch, best advice is if you neither have the tooling to make a staff is keep it for spare or sell it on for spares
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
