Tissot 7842
Hi   I have attached the tech sheets  for the tissot models  as there seems to be a lot of parts which are common across the range.  The balance complete is 720 without spring and 721 with spring attached, so by the fact it is supplied as a spare it is detachable.  the spring its self does not look too bad and most probably be re curved ok.  If you could supply a picture of the balance and cock laid upside down so members can see the attachment it would be a great help.       cheers
2790_Tissot 781.1,782.1,783.1,784.1 (4).pdf 2789_Tissot 781,782,783,784 (2).pdf 2791_Tissot 783.2,784.2 (1).pdf
 W W is right, if you show a picture of the cock laid upside down, we have a chance to figure out how to detach the HS and if the collet is removable then sorting the HS out and shaping an end curve isn't a tough task.
A top view with balance pivot inside the jewel hole, would be helpful.
2790_Tissot 781.1,782.1,783.1,784.1 (4).pdf 2.84 MB · 0 downloads 2789_Tissot 781,782,783,784 (2).pdf 4.14 MB · 0 downloads 2791_Tissot 783.2,784.2 (1).pdf 1.26 MB · 0 downloads
Thanks for the response heres an image
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
