Brass bushes for Omega 455
I need 4 brass bushes for the automatic movement of an Omega 455 (small!), but can't find any from the usual suppliers I use.
The size is 1.00 x 0.2 x 0.22 (dia, hole, ht).  Cousins have the complete upper bridge, but then I still need 2 for the lower.
I could use jewels in the lower bridge, but the nearest Seitz size is 1.40 x 0.20.
Can anyone help ?
5 minutes ago, oldhippy said:
I can only find these. Do you have the means and skill to make them? Have you tried ebay? You should be able to find what you want in a selection. Here is the link to what I found.
https://www.cousinsuk.com/product/watch-bushes-by-size
That was the first place I looked,  and unfortunately, not the right size.
obsoletewatchandclockparts has a selection, but again, nothing close enough.
Nothing on ebay, but I'll keep watching.
1 hour ago, Nucejoe said:
Would you also disclose how you determined the bushes to be defective. Do you examine and go by side shakes? depthing between gear and pinions?     TIA
When the hole is shaped like this
28 minutes ago, Colditz said:
 if you cannot get the right bush then I'd be tempted to increase the hole size and fit a larger bush with the correct hole size and employ friction fit. You can use a broach to do this.
I would do that, but I can't find any with a 0.20 mm hole size
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
