Illinois pocketwatch winding stem broken?
Hi everyone, my name is Ollie. I’m a motorsport engineering student from northwest England.
I’ve always been interested in the engineering behind mechanical watch movements, so I recently started collecting broken pocket watches with the intention to try to coax them back to life (as yet with surprisingly successful results!).
I have an Illinois pocket watch that came with the winder not attached to the watch. Upon dismantling I found there is a small ‘pushrod’ (please excuse my lack of knowledge), inside a separate winding stem with a square female drive which I assume the winder sits in and allows it to float backwards and forwards, pushing on the ‘pushrod’ so you can change the time. Shown in pictures.
How can the winder stay inside this mechanism, as it just slides straight out (there is no physical way of stopping it)?
I had wandered whether the ‘pushrod’ should be attached through the stem to the winder, which would hold it in place because the end of the ‘pushrod’ is flared preventing it from sliding through the winder.
Thanks, and I look forward to hearing the replies.
Does not appear to be broken, looks like a 2 piece stem. I believe it is supposed to be this way. There is supposed to be a collet that screws into the case that keeps the crown from slipping out.
Now you're design may be different, but this is the most typical. I have had the segments with the fine slits break off and then the stem won't stay in place anymore.
Edited by FLwatchguy73
Thanks for your reply!
My crown however doesn’t look as though there is anything physically there to interact with a collet to prevent it from coming out (see picture).
It has to slide up and down inside the outer ‘sleeve’ and push on the ‘pushrod’ to allow you to change the time.
Typically on the majority of American pocket watches the movement is set up similar to yours.  This is where the watch itself has no stem as that is in the case. So your movement is fine make sure when you're putting it together to lubricate all of the stuff associated with the setting so it's slide smoothly.
Link down below so you can look at the pictures. It's not really important but you're missing the micro regulator adjustment. You can still regulate the watch fine without it.
Then the crown is most definitely does not look like the right crown for this particular case. It almost looks more like a wristwatch style crown for American watches. I went attached some images you can see what the wristwatch version looks like. Also a picture of the typical pocket watch stem and sleeve arrangement.
https://pocketwatchdatabase.com/search/result/illinois/4927242
This negative-set design was used a lot on early wrist-watches and thin pocket watches, especially those with a low rigid-bow like the one you show. I wish you luck finding something. It's not going to be easy. The good thing is that the sleeve is not threaded into the pendant so the fit has more tolerance. Good luck.
BTW, that image is from the Chicago School of Watchmaking courses. They are very handy for working on old watches, pocket watches in particular. And they are widely available on the internet in digital form for not too much money. I have the hard copy as well as the digital. Today I reference the digital a bit more often. Enjoy.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
