Illinois pocketwatch winding stem broken?
Hi everyone, my name is Ollie. I’m a motorsport engineering student from northwest England.
I’ve always been interested in the engineering behind mechanical watch movements, so I recently started collecting broken pocket watches with the intention to try to coax them back to life (as yet with surprisingly successful results!).
I have an Illinois pocket watch that came with the winder not attached to the watch. Upon dismantling I found there is a small ‘pushrod’ (please excuse my lack of knowledge), inside a separate winding stem with a square female drive which I assume the winder sits in and allows it to float backwards and forwards, pushing on the ‘pushrod’ so you can change the time. Shown in pictures.
How can the winder stay inside this mechanism, as it just slides straight out (there is no physical way of stopping it)?
I had wandered whether the ‘pushrod’ should be attached through the stem to the winder, which would hold it in place because the end of the ‘pushrod’ is flared preventing it from sliding through the winder.
Thanks, and I look forward to hearing the replies.
Does not appear to be broken, looks like a 2 piece stem. I believe it is supposed to be this way. There is supposed to be a collet that screws into the case that keeps the crown from slipping out.
Now you're design may be different, but this is the most typical. I have had the segments with the fine slits break off and then the stem won't stay in place anymore.
Edited by FLwatchguy73
Thanks for your reply!
My crown however doesn’t look as though there is anything physically there to interact with a collet to prevent it from coming out (see picture).
It has to slide up and down inside the outer ‘sleeve’ and push on the ‘pushrod’ to allow you to change the time.
Typically on the majority of American pocket watches the movement is set up similar to yours.  This is where the watch itself has no stem as that is in the case. So your movement is fine make sure when you're putting it together to lubricate all of the stuff associated with the setting so it's slide smoothly.
Link down below so you can look at the pictures. It's not really important but you're missing the micro regulator adjustment. You can still regulate the watch fine without it.
Then the crown is most definitely does not look like the right crown for this particular case. It almost looks more like a wristwatch style crown for American watches. I went attached some images you can see what the wristwatch version looks like. Also a picture of the typical pocket watch stem and sleeve arrangement.
https://pocketwatchdatabase.com/search/result/illinois/4927242
This negative-set design was used a lot on early wrist-watches and thin pocket watches, especially those with a low rigid-bow like the one you show. I wish you luck finding something. It's not going to be easy. The good thing is that the sleeve is not threaded into the pendant so the fit has more tolerance. Good luck.
BTW, that image is from the Chicago School of Watchmaking courses. They are very handy for working on old watches, pocket watches in particular. And they are widely available on the internet in digital form for not too much money. I have the hard copy as well as the digital. Today I reference the digital a bit more often. Enjoy.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
