Illinois pocketwatch winding stem broken?
Hi everyone, my name is Ollie. I’m a motorsport engineering student from northwest England.
I’ve always been interested in the engineering behind mechanical watch movements, so I recently started collecting broken pocket watches with the intention to try to coax them back to life (as yet with surprisingly successful results!).
I have an Illinois pocket watch that came with the winder not attached to the watch. Upon dismantling I found there is a small ‘pushrod’ (please excuse my lack of knowledge), inside a separate winding stem with a square female drive which I assume the winder sits in and allows it to float backwards and forwards, pushing on the ‘pushrod’ so you can change the time. Shown in pictures.
How can the winder stay inside this mechanism, as it just slides straight out (there is no physical way of stopping it)?
I had wandered whether the ‘pushrod’ should be attached through the stem to the winder, which would hold it in place because the end of the ‘pushrod’ is flared preventing it from sliding through the winder.
Thanks, and I look forward to hearing the replies.
Does not appear to be broken, looks like a 2 piece stem. I believe it is supposed to be this way. There is supposed to be a collet that screws into the case that keeps the crown from slipping out.
Now you're design may be different, but this is the most typical. I have had the segments with the fine slits break off and then the stem won't stay in place anymore.
Edited by FLwatchguy73
Thanks for your reply!
My crown however doesn’t look as though there is anything physically there to interact with a collet to prevent it from coming out (see picture).
It has to slide up and down inside the outer ‘sleeve’ and push on the ‘pushrod’ to allow you to change the time.
Typically on the majority of American pocket watches the movement is set up similar to yours.  This is where the watch itself has no stem as that is in the case. So your movement is fine make sure when you're putting it together to lubricate all of the stuff associated with the setting so it's slide smoothly.
Link down below so you can look at the pictures. It's not really important but you're missing the micro regulator adjustment. You can still regulate the watch fine without it.
Then the crown is most definitely does not look like the right crown for this particular case. It almost looks more like a wristwatch style crown for American watches. I went attached some images you can see what the wristwatch version looks like. Also a picture of the typical pocket watch stem and sleeve arrangement.
https://pocketwatchdatabase.com/search/result/illinois/4927242
This negative-set design was used a lot on early wrist-watches and thin pocket watches, especially those with a low rigid-bow like the one you show. I wish you luck finding something. It's not going to be easy. The good thing is that the sleeve is not threaded into the pendant so the fit has more tolerance. Good luck.
BTW, that image is from the Chicago School of Watchmaking courses. They are very handy for working on old watches, pocket watches in particular. And they are widely available on the internet in digital form for not too much money. I have the hard copy as well as the digital. Today I reference the digital a bit more often. Enjoy.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
