As 1882
rogart63
Having trouble with a serviced AS 1882 . This watch is only making a lot of trouble . At first i bought it and it didn't work so very well . Tried to service it but it didn't go so well . Something wasn't right  . Could get the part together . So i bought a nice looking watch with the same movement cheap . That movement is now serviced and running strong . It works ok in the timegrapher . But the hands won't follow the movement . The hour and minute hands stops or is slow . But the second hand works and keeps ticking .  I will soon get an old movement that missing some parts .Which i have from the first movement . Going to get that movement serviced and see if i can get it to work in the other nice looking watch . What is the trouble with hands ?
Edited by rogart63
+1 for Geo's reply - I've had this problem with a number of movements over the years. Slow or wobbly and unpredictable movement in the minute hand - corrected by either tightening or replacing the cannon pinion.
Hi Rogart, I have become abit of an expert on the AS movements after purchasing a Mido with a similar problem, 3 movements later I got it working!. It is the small gear on the end of the Large driving gear that needs to be tightened. Its part number 201/1. The Canon pinion is driven from that along with the date change mechanism. Cousins have the parts list if you search for AS1882.
Actually suspected that  gear . What should i search for on Ebay ? Cannon pinion tighten tool ? .
Canon pinion tool would do it there is one here in this lot , it is the tool in the top left hand corner of the box ebay item no 191502866512
Edited by Andyclient
Here's mine, it's a set of wire cutters that I have drilled and tapped to accept a screw to limit the amount of squeeze that you give the pinion.
If you go this route it is easy to make very small adjustments at a time until you get the correct fit. It can be done without using a drill or a mandrel in the pinion if you are very careful, but it is a lot safer to use one. Remember, this is a trial and error fitting exercise to get the best fit.
  • Like 5
If you have a staking set there should be a stake or a stump that would work.    BE VERY CAREFUL NOT TO OVER DO IT.   broaching the whole out after it has been dimpled too much is a real pain.   Personally I would use the staking set or an actual cannon pinion tightening tool   that in like a mini staking set.  I don’t like the clipper type if the cannon pinion is thin as in the offset cannon pinion type is. It is very easy to destroy it by over-tightening it.    I have attached a photo of the one I use
Sincerely,
Jim
I prefer using the cutter style tightener, same as geo's. I find you get the most control and it is nearly impossible to fudge it. I still slide the CP down an old oiler first, but the screw on the cutters make it impossible to crush the CP in any case.
I will defer to you here Mark   putting the CP over an old oiler is brilliant  thank you.    The thin offset ones have always given me trouble.  I have over done a few  :-(
Thanks again for the post
Jim
Have fix the cannon pinion and it has been ticking with some odd hands i had in a box . Just to see if it works ok . Now i can put the datewheel and date mechanism back again . Had to do it a few times and had to support  the wheel from the other side when i pushed it on . Looks a little strange with hands .It's 8 a´ clock
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
