Spring wire
Hi. I was wondering if anyone knows a good source of very fine spring wire suitable for making watch click springs? I’m trying to make an obsolete click spring for an old Seiko. I really need 0.2mm gauge. The finest Cousins sell is 0.3 which is actually 0.4 when you measure it. I also found some on Amazon which says it’s 0.2. But it’s quite expensive and comes in various options, zdx, hww... I’m not sure what the difference is and the description of each wire is identical. Just the price differs. Any advice appreciated. Thanks!
I had the same problem some time ago.
Finally, I bought a guitar string and voile, job done. (PL008 0.200 mm)
Actually, it measures 0.18 mm on my caliper.
Try this site:- WWW.DADDARIO.COM
Good luck, I'm sure you will find something there.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
