Looking for Omega cal 381 part
Hello, I'm trying to locate a date wheel for cal 381 which has broken in my watch and unfortunately means the date functions don't work properly.
I'm looking for part 1512
Any help greatly appreciated :)
Thanks
Fred
Unknown.jpg.7e83be24cbdeb0a63d17e7274a2437fe.jpg850388190_Screenshot2020-06-01at16_33_12.thumb.png.1ed0f7f00629590cd4b215d7c84fc61d.png
What happened to your old one? is it buggered?
I would set a saved search on ebay for " omega 381 1512" - thats how I found a NOS dial for my 381.  Mind you it cost $1200 US
9 hours ago, watchweasol said:
Hi   Have you tried these,   obsoletewatchandclockparts.com       welwynwatchparts.co.uk        speedtimerkollection  in Europe.
all purveyors of new and used parts and movements.      cheers
No luck there, but thank you @watchweasol :)
@AlexeiJ1 Many thanks for the suggestions. I've messaged Blake and Railmaster. Old one has the spring end broken on the cam unfortunately. Will also keep an eye out on eBay. Congrats on finding a NOS dial on the 381, that's pretty amazing and I'd say worth the price. Mine is a very old redial I suspect, but a charming one, so I'm going to leave it as is.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
