Swiss emperor
Pretty much know that already, was wondering if anyone that knows anything about watches can tell me how old it Is, why its heavy, ect not to bothered about the cost as its more sentimental value. Was just curious.
The Swiss Emperor brand was registered in 1959 so it's no older than that.
Swiss Emperor was a decent quality brand targeting the better end of the lower price range watch market. Not budget, but very much aimed at the average wage, possibly on a par with the Seiko 5 range still marketed today.
The styling suggests that it's from around the late '70's or early '80's. The stainless steel back suggests that the bezel is gold plated (solid gold bezels usually come with solid gold backs) if you look closely you may find it is stamped between the strap lugs with something like "GP20" or "Plaque 10" indicating the gold plating thickness in microns.
(Silly me... integrated strap so no strap lugs as such, but there could still be a stamping beneath the strap)
At a guess it probably houses a Peseux movement. These were very popular in two hand or sub-seconds dress watches of the period due to their thinness.
It's a nice looking 40-ish year old dress watch that should be capable of good performance if it has been maintained.
Edited by Marc
correction
Looks like a 1970's/ 80's with an attached bracelet which is a bugger if the bracelet breaks or gets damage, very bad design. The movement is just standard swiss, anything other then round and you have problems with dirt getting in.
Sorry,  yes sentimental, invaluable it is.
  • 1 year later...
    • I found this from a while back CS100 seems fine, but at around 500 Vickers it's not quite as hard as "blue" steel, but still harder than annealed. I'd try to find annealed (the post above has a U.K. supplier of small quantities).
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.  Thanks, Nev. Amplitude v. weak - balance wheel turns over arc of only ~20deg. Don't know how to calculate movement rate or safely vibrate balance spring! Meantime I have reduced the 'dishing' & clock no longer runs for more than a few minutes except face down which supports my theory that it was 'dished' as a hack to avoid doing a proper repair.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
