Server Issues Today
Mark
Another problem with Cloudflare today. Things are a bit slow. It's a bugger to be honest.
Update - Removing congestion from IAD.
Feb 12, 20:32 UTC
Update - We are actively working on alleviating network congestion in some of our European datacentres.
Feb 12, 19:59 UTC
Identified - The issue has been identified and a fix is being implemented.
Feb 12, 08:50 UTC
Investigating - We are investigating network issues in Frankfurt, the colo has been rerouted.
Feb 12, 06:29 UTC
Don't think so - mainly referring to the general slowness of the site a few days ago. It should all be resolved now.
I have taken my other site off cloudflare to see what difference it will make before I make a decision about WRT. hopefully it will be better from now on.
  • 4 weeks later...
I couldn't access the site today because the host didn't resolve… I'm using Google's dns and checking the domain gives a SERVFAIL error:
# dig www.watchrepairtalk.com @8.8.8.8              ; <<>> DiG 9.8.5-P1 <<>> www.watchrepairtalk.com @8.8.8.8;; global options: +cmd;; Got answer:;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 15544;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0;; QUESTION SECTION:;www.watchrepairtalk.com.	IN	A;; Query time: 55 msec;; SERVER: 8.8.8.8#53(8.8.8.8);; WHEN: Mon Mar 09 12:37:31 CET 2015;; MSG SIZE  rcvd: 41
One possible reason for this error is that the DNSSEC configuration is broken.
Access was very choppy with googles DNS servers (8.8.8.8 and 8.8.4.4)
In fact it was for several domains I visited.
Changing back to the BT DNS servers and all is fine.
I did a check http://www.intodns.com/watchrepairtalk.comand all seems fine with the DNS records (the two errors stated are beyond my control and do not cause errors for DNS queries for A and MX records).
Checking further I find that it is a problem for some domain owners who use the Google DNS service: https://groups.google.com/forum/#!topic/public-dns-discuss/7Dd4pzBfpZA
As it is - I find nothing to fix but will keep monitoring just in case.
Thanks for reporting Rob.
Well done for finding that Rob.
I did look on the service status page at eNom but didn't see any issues, the article explains a lot.
If it happens again, I will look into deploying my own secondary DNS. It's a shame - I was using eNom's DNS service specifically to reduce admin overhead. Mind you - i've been with them for many years and the provided DNS service is usually quite stable.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
