Omega Dynamic auto/date movement retention
I have one of the above - a 1967/8 model and off hand I can't recall the cal. Someone else serviced it for me (a friend who has done lots of work on higher value/complex movements for me). After using it for a while - timing's very good - the split stem suddenly popped out. The movement had rotated slightly and I had to take it out end push the inner stem back into the setting position before re-casing the movement and refitting the outer stem. Everything was fine and I wore the watch on and off for a week or so, letting it run down and resetting occasionally. All good. Next time I picked it up to reset  it the stem fell out again and I can clearly see that the movement is slightly rotated. I bought a new stem with my next order from the cousins. However I don't think that wear is the problem. The original is mighty tight to refit. I think the problem is that the movement, er, moves and the stem parts slip apart horizontally (or nearly so.)
I don't want to pester my friend about this. We do barter deals and he's got a lot on his plate right now. So, can someone tell me how the movement is secured? I realise that it rotates clockwise from the 11.00 position to secure in position  but I also recall that it didn't feel like a very positive location. I could substitute the new outer stem temporarily as an experiment but I'm pretty sure this isn't the problem.
As an aside, split stems along with spring loaded detents are two pet hates.
Any relevant advice would be appreciated.
Roy
I've asked. It came originally from SE Asia and anything is possible. Cosmetically good though. I've just opened it up -again - and it's a cal. 565. It doesn't do my nerves any good handling it because that unobtainable sweep second hand won't tolerate a single refit...
There are different cases for these front-loading types, but it’s worth mentioning that some use plain, flat movement retaining tabs which are simply screwed into the movement to provide a key into the case.
Also, do you have an original Omega tension ring crystal fitted?
3 hours ago, RoyC said:
It has the original crystal but the fit, while firm, is not what you would call tight.
That doesn’t sound right to me as it should be very tight. From memory, they aren’t just a plain ATC - they have a ridge around the edge which secures them at the correct depth. The tension ring is sized to secure the edge of the dial, at least on the Cosmic version anyway.
Did you confirm that the two movement securing tabs are present or not?
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
