A little help opening this watch
Getting a snap-on case back off using a blade can be very efficient but requires some dexterity and there's a risk you'll scratch the watch and/or hurt yourself if you slip. I use a blade myself but to me it's a pain every time so for that reason I try to stay away from snap-on case backs. It can also be a pain to replace the case back. It's not always possible to press it back by hand and in those cases a crystal press is needed.
I've just ordered a tool designed to remove snap-on case backs and bezels. I primarily ordered it to remove bezels. I don't know if it is any good. It was inexpensive (unlike most watch tools), so I decided to take a chance. Click here to see it. You can get it for less if you take it from China or AliX.
Good luck!
4 hours ago, dormantkerosene said:
As. you can see with the indentation, it's faded out and I can't pry the watch back open. What should I do?
It would probably come off using properly a dressed knife and sturdy case holder into the hands of an experienced person, but it's also true, as noted above, that these can be really tight and difficult to deal with,
The specialized tool also mentioned is the one that I covered in a previous thread below, I suggest that you search the forum a next time, most question have been asked and answered before. Also, very likely that you will also need a case press to close it, all in all it may be much less expensive and complicated to give it to a watch shop.
    • Hello!  Does anybody have this tool?  This is mine.  If you have one, does it look complete?  How do you use it.  (I have the instruction sheet but it's hard to read!)  thanks!
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
