screw head
Hey
Any way suggest the best way of removing this screw.
Do not want to drill it incase i destroy the thread.
Ain,t there some chemical i can use that will dissolve the screw but not the bridge?
cheers
gary
As long as you remove all of the other steel component so you only have the plate then you can use alum mixed in water and that will dissolve out the screw. If you're in a rush you can warm up the solution It will dissolve it out faster.
I have the Bergeon tool "Kraai" shows via a video.  Expensive as always with Bergeon but works a treat. I have not had much success using Alum but I suspect it must be my method the only issue is the amount of time it takes.
I tried and failed with alum on a battery spring/retaining screw on a Seiko 7548. Several days and a very concentrated solution but the screw remained unimpressed by my efforts. As you can see, I may have got carried away with the strength of the solution, it became crystalline over a few days in the airing cupboard.
I have now ordered a Bergeon type tool. Where from? Well, let's just say that when it arrives it will be disinfected in case the person who packed it had a bat sandwich for his breakfast.
That is the only bergeon tool I ever bought as I thought it is a life saver. I used it twice so far, both times I brutally damaged the main plate. I still have nightmares. :) However knowing about myself probably I was not careful enough and I had no experience or has no experience yet as how to use it properly. I seem to have difficulties to understand that you have to take your time when you deal with watch movements.
The crown shaped end of the tool could not get a good grip on the broken screw by the way and I made also a mistake not to use the proper sized tool originally and when I used the right size? it was already too late. Was too hasty etc. The watch i prepared as an xmass present for Mrs still has the broken screw and this thing never goes away... i must fix it sooner or later as it will haunt me forever.
Edited by luiazazrambo
That most probably was a stainless steel screw. Modern screws often are SS.
Frank
Frank
And as stainless steel has a lower tensile strength than the corresponding carbon steel equivalent, makes it more likely to shear off......and while the stainless won't rust, damp can cause galvanic action where the brass plate it is screwed into can start to corrode....
Gonna quote Luke in the Cantina here: "I'll be careful." I have a spare mainplate on the way so I'm covered if I balls it up but I'd rather get the screw out if I can.
Frank
I guess you are right. I have a big bag of alum and not a lot to do with it. I could pickle some onions later in the year!
That's 99.999% sure a left hand thread, I've found that screws are often rather loose in their threaded hole once the head breaks off, see if you can get a grip on it with strong tweezers and go righty-loosey. You can mimic the Bergeon tool somewhat using a staking tool to capture the screw by each end and turn the bridge to unscrew.
Don't you mean a tin of this?
I also managed to get out a screw similarly, used a bit of penetrating oil and with a lupe and with fine tweezers a managed to rotate the screw by the fraction of a mm by pushing the outer side of the screw as many times as it was required to be able to grab it at the end of the process. I guess it only works if the screw is not seized in its hole too much.
I also think that i am now in a better position with using the bergeon tool having a stereo microscope with ring light so I could actually see what I am doing instead of being blind and go with full speed. :)
1 hour ago, Nucejoe said:
In this case, enough of the screw sticks out to grab with a nail clipper or needle nose pliers.
Is there a reason a pin vise isn't in that list? First thing that came to my mind, but it's not something I've been faced with on this scale before.
Edited by spectre6000
I usually end up trying every tool I think may work.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
