Burnishing
Pip
Afternoon all,
I have been rummaging through my collection of bits I have yet to use that came from various sources. As I'm embarking on learning to turn, with the intention of producing some balance staffs (great videos by the way @jdrichard, thank you for taking the time to make them) I am looking at what comes after, ie burnishing.
I have most of a jacot tool, it's missing the 'drum' (not sure what the part is called). Is it likely I will find one somewhere or is it a lost cause?
Or is there an attachment for my lathe (Pultra 10) that I can use instead of a jacot?
I also have what I think is an old burnishing tool to use with a jacot, am I right in thinking this is what it is? What's the best way to clean one of these up?
IMG_5680.thumb.JPEG.3a8ba115f3402ddb6a6389dbb6ae51ff.JPEGIMG_5682.thumb.JPEG.a8662ebd0eb3fe12a66e95b79a65d0f5.JPEGIMG_5683.thumb.JPEG.88020258d6b1acf5a01e9921f45e3eb4.JPEG
Thanks in advance. I'll get there in the end, if it damned well kills me!
Hello,
New lanterns can occasionally be found but it is rare. More often these tools are sold with damage to the same parts. It is possible to make or repair the parts which are damaged with a combination of tools which will generally differ by whether they include a 90 degree double angle milling cutter or a tiny drill - for grooves or holes. Off the top of my head, the depth of grooves with a 90 degree cutter is a depth of 0.65 times the desired pivot diameter.
I'm assuming the issue is with the disk with tiny holes in it.. it can be possible to anneal the damaged end and to turn most of it away, leaving a boss concentric with the outer diameter which fits through the tool. The end of the boss can be tapped for a retaining screw for the new part, or the new part can be glued/ bonded on the end - both parts will want to be a nice close fit so that the new part remains concentric if drilled before being mounted to the old arbor / part of the tool. The new disk can be steel or brass (they don't see a massive amount of wear but may have abrasives embed in them, and will wear out quicker than steel). In order to drill one you'll need a way of indexing so that you can use the tools existing divisions (the star shaped part and guide). It is possible that a new disk may be able to be drilled or center drilled in place on the tool with some creativity.
I've also got a jocot tool with a damaged disk, shall repair it eventually but just use another for now.
Your other tool may still be or have been a combined pivot file and burnisher. It depends how it's been used in the past as to what it will be like now. One or both ends may be dressed as a burnisher - depending what sort of tool they presently appear to be, if one end is still a pivot file then you may wish to keep it as one.. a pivot file is useful so I'd keep it as one if it's in even partially worn condition.
Basically to dress a burnisher you could use traditional techniques such as oilstone dust on a lap with a bit of oil, or nowadays you could use a modern abrasive of a similar grade. The process creates tiny grooves in the tool from the abrasive which do a combination of really fine cutting and burnishing the pivots you apply the tool to. The burnisher would be moved across the abrasive and rolled over part way through the stroke, starting with a large face then rolled onto the next smaller face. You will see that there should be 2 sharp edges and 2 rounded edges, that will indicate which edges are rolled over and which shouldn't. It will probably take a bit of time if there are any imperfections or surface rust, etc to remove - you may choose to work on a side at a time to flatten and remove imperfections before dressing it.
Edited by JGrainger
addition
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
