Initial greetings
RoyC
Hi. My name is Roy and I'm an amateur horologist aspiring to be less amateur. I'm in my 70s, groan.
I've collected (ie accumulated) modestly for decades. Nothing very exotic because my income has always been distinctly non-exotic. Though one of my closest friends I've also acquired a vast quantity of unsold parts, movements and complete watches. For the last few years I've been working through them, selling off the immediately usable items and gradually working my way though them, repairing at various levels of complexity  and difficulty. Lots of crippled  watches in my wake but it's getting smaller. Like most things in life you have to start out being very bad at difficult tasks, passing though the slightly less bad and approaching the not too bad if time permits - which at my age is a constant consideration. I wish I'd started on this path earlier however "if i knew then what I know now.... etc" is a refrain that most of us start singing if we live long enough.
I'm fortunate in that I have a good relationship with a horologist who does the more demanding work for me. We're also friendly so it's better than a purely commercial relationship. I try not to pester him too much for advice. I'm always in need of advice.
Mark's tutorials are simply outstanding - there's nothing else that I've seen on YT that even compares where this subject's concerned.
Roy
PS Anyone got a spare good LIP T18 balance kicking around that they don't need?  I have a good HS. Well, you gotta ask.......
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
