Hamilton GMT Hands Changing
I am having a problem clearly seeing the time on my Hamilton Jazzmaster Traveler 2, as the hand color is not at all in contrast with the face of the watch. Where can I source the proper hands and would there be an issue re-handing this watch.3746b37249d051c2b07404ec69423a0f.png695c89489da8a83e4b45d3ac1fbd8e4b.png
The watch is based on an ETA 2893-2 movement -- I have that watch, too. There are plenty of handsets for that movement on eBay for $15 ~ $25, but I'd have to agree with oldhippy. A fine brush and small jar of enamel paint from the local hobby shop (assuming one is open, now) is a $3 investment for exactly what you want.
But no lume
Yes ithink you are right as a contrast to the stainless steel a nice dark blue would be perfect.  The good thing id if you dont like it you can always clean it off.  There used to be a chemical used for blueing gun barrels that would make a nice dark metalic blue.
1 hour ago, jdrichard said:
But no lume
It doesn't have any now, and the lume on that watch is pretty weak to begin with. In any case, the problem I can see is the hole for the GMT hand is 1.8 mm and it's current length is around 8 mm. Most GMT hands with a 1.8 mm hole are 13 mm and up. The GMT Jazzmaster has that rotating chapter ring that would start interfering with the hands at about 14 mm.
This is my take on what that kind of mod might look like.
If you're okay with that, it's a $4 purchase. https://www.esslinger.com/alarm-calendar-gmt-and-24-hour-watch-movement-hands/
9 hours ago, jdrichard said:
I will screw that up for sure
I agree with Old Hippie.  I have an old Luminox that I wore when I was in the field (electrician).  The only metal is the crown and clasp.  I took a short length of #12AWG wire, which is made up of many finer strands, and curled the wire to create a base/pedestal, stripped off about 1/2" of insulation, and separated the strands into, sort-of the spokes of a half-opened umbrella, sort of V shaped.  I placed each hand on a strand, manipulated until I had the hands with the visible faces upright and horizontal, placed on a piece of large newspaper, and hit the gold hands with black spraypaint with very light, quick swipes.  Repeated until the hands were colored, and voila.  Didn't even have to broach the holes.  A look at the watch now, you'd never know the hands didn't come black.
Don't see why you couldn't do the same.
Edited by SparkyLB
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
