Yet another newbie... from Sydney Australia
JAHM
I think I just introduced myself to an automated welcome response so I'll try again
Evening All. My name is John and I am from Sydney Australia. Thank's for the warm welcome. It has got to the stage that retirement is looming so I felt this is a good time to start a new hobby that, with the inevitable downsizing, will require less space.  Previous passion is automotive restoration (MG's specifically), which although I am still passionate about, will have to take a back seat. ..I'll just keep restored ones.
I have decided to focus on Seiko (like many) as I love the older examples that I had as a teenager. I still have the 6138 - 8020 chronograph and the 4006 Bellmatic which will be the first to undergo work.  I will however practice on other later and cheaper examples that I can break without being too upset.  Retirement is still two years away so I have a bit of time to gather the right tools and commence setting up a spare room. I've just ordered a sit to stand corner desk which should help with the height required for working.
Additionally, I have purchased an Elma (Super Elite I think) watch cleaning machine (late 60's) following reading a wonderful thread on this site, that is ripe for a full restoration. It arrived here in Sydney today (all the way from South Australia). I get the feeling that the Aussie posties have kicked it from one side of the truck to the other as it arrived with one broken bottle/jar and a rather sad looking, but passable, speed regulator knob . Just wondering if anyone is parting out an old example as I would prefer to retain the look of the older materials glass and bakelite/plastic..Just let me know. If not I will have to buy new.
I look forward to immersing myself into this field and learning a lot just by reading your posts.
Kind regards and cheers, John
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
