Help with movement Otero 256
Hello everybody
I bought on a flea market a nice lady watch from the (i believe) '70. If i am wrong with the datation, please let me know.
The hour was told by plastic rings (please check the pictures below)
On the hour wheel is attached a "wire".
As when I opened it, the numbers were "flying" I am NOT sure how the plastic rings were fixed and if it is complete.
Somebody can help with the above 2 questions?
As the movement is really tiny, I am definetely not going to work on that IF there is sommething missing or broken.
Many thanks in advance
Buf
Hi and welcome to the forum,      As to the watch what you have bought is a jump dial watch and in a bit of a state with the rings loose and probably the detents/springs missing , I also botice the balance wheel and cock are also missing.  This is not the best watch to start on. for information have a look at          ranfft otero236  with google.  I have had a quick look round for a tech sheet but found nothing listed.
Thanks for your answer; I apologize for the misunderstanding: I have the balance wheel: I took it off to discover the movement number!!
