Hello from Dubai!!
GJM
Hello Everyone, hope you're all safe and in good health.
I'm really excited to be part of this community.
Presently, I'm on the 2nd level of Mark's watch repair lessons and already have my grandfather's wrist watch as my first and ongoing project. It's a Ricoh calibre 61; nothing too great or fancy but I think I wrecked the watch years ago and now that I've picked up this hobby and the basic tools, I've taken it upon me to fix this watch and get it running again.
If any of the mods want to may be tell me if there are people in this community that specialize in any areas of watch repair then that would be much appreciated.
Thanks and stay safe.
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
