Dial Cleaning
Working on a Hamilton 992 with a dirty dial. A fine cleaning with Rodico followed by targeted removal of spots and blotches with a toothpick; and then a cleanup with Rodico and Ta Da.
852b50ca2bddd21baf4da6b54276cf33.jpg43e69ac00b8dfc654451c9f635fb0ca8.jpgf9c756ba0c960b12443ba4ac073929e2.jpg
And the movement was cleaned with Rodico as well. Being very careful not to touch the jewel holes. This PW has a swing of 540 Degrees.
  • Like 5
8 hours ago, spectre6000 said:
How does that work?
Total arc of swing from extreme clockwise point to extreme anti-clockwise point is double the amplitude. So a swing of 540 degrees is an amplitude of 270 degrees.
Thanks Marc. I usually use my iPhone in slo-mo to observe the swing. I also bought eTimer for looking closely at the performance. Would it be possible for you to make a video on how to use eTimer for diagnosing watch problems. Their manual is not sufficient.
4 hours ago, jdrichard said:
360 plus 180 :) Full swing. Amplitude is 1/2 that value
Right. Duh. I read it as amplitude. Don't usually see it stated in terms of full swing. Opposite of BPM and Hz. I think in Herz, but it's always stated in terms of BPM.
No. Used a toothpick to remove the yellow stuff!! Then cleaned up with Rodico.
So, you scraped every square mm of the dial with a toothpick, and yellow schmutz came off? Interesting... Seems like that's a porcelain dial-only strategy.
I scraped those areas with significant blemishes or moisture bumps, but I did do the whole dial carefully with Rodico
  • 8 months later...
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
